 Post subject: Bad sectors all hdd (toshina 250GB)
PostPosted: November 19th, 2012, 13:49
Hi
i got toshina 250GB with dad sectors all the hdd. I used HDD Regenarator V1.71 it can recovered but it will take 404 days. Can anyone give advice to solve the problem quickly?
Note:need to recover the data
 Post subject: Re: Bad sectors all hdd (toshina 250GB)
PostPosted: November 19th, 2012, 14:02
Have you tried with MHDD?
ACELab partner
PostPosted: November 19th, 2012, 17:19
redseaksa wrote:
Hi
First stop using that software.
Then : 1) diagnose what the problem is (no more than 20 minutes) - 2) put PC3000 UDMA at work and thoroughly check the disk (10 min. max) , 3) determine if media / heads / mechanics are OK and eventually fix it 4) clone the drive and extract data from the clone.
It is the quickest and safest way (and the only one I'm afraid).
If point 2) is not feasible, replace point 2) with OUTSOURCE and leave the problem to the guy who will handle the case.
PostPosted: November 20th, 2012, 3:55
Thank you
Users browsing this forum: No registered users and 90 guests
