 Post subject: Who can recover the data from my hdd?
PostPosted: November 18th, 2012, 3:46
some days ago I posted here about my problem. But not, I write you directly if somesome could quote how much it could be the recovery if he/she do it.
I already tried to contact pcimage in three different ways but he did not answered my mails, probably in the forums I can have more luck.
It is just personal stuff, photos and some offices doccuments, which is really important. I would like to recover but I do not know if I can afford it, so I would like to have a quote.
I write again the problem and the alrready taken actions:
This is the information of the HDD and PCB:
Seagate Barracuda 7200.10 250GB ST3250310AS
P/N: 9EU132-305
firmware 3.AAC
site code: WU
CHIP: TTB5041A0
TVS diodes are OK.
I have swaped a pcb from one bought in onepcbsolution.
When I power on the computer it takes, something like 10 seconds to show in BIOS start-up the IDE/SATA peripherals. Also, only half of the times the drive is detected.
The drive, always spin up, without noticeable noises.
The drive has 2 primary partitions and 1 extended with 2 logical partitions inside.
I've tryed to rescue booting with a linux distribution called SystemRescueCD.
Most of the times a fdisk -l command shows the partition table (the rest, connection to drive seems to be lost).
I cannot mount the drive.
I have made an image with ddrescue to work only with the image, but during the process (almost 2 days) it detected so many errors, than I cannot find useful data in the image.
I think services in Europe are better for me, because of shipping costs (I live in spain).
Thanks again and best regards,
Angel.
 Post subject: Re: Who can recover the data from my hdd?
PostPosted: November 18th, 2012, 5:46
Proper diagnose is needed so you have in any case to send the drive in for evaluation. And be honest : how much (max.) can you afford / are you willing to spend?
PostPosted: November 18th, 2012, 6:47
Thank you BlackST,
Ok, do you (or someone else) think that it could be done for something under 200 Euros?
I mean, taking into account the things that have been already done with the drive:
- Swap pcb. I provide the original and the replacement, if it can help.
- Drive cloning with ddrescue
- testdisk with the image or the drive.
Thanks in advance.
PostPosted: November 20th, 2012, 2:59
nobody can do it?
The problem is the price? If so, please provide a better estimate.
Thank you.
PostPosted: November 20th, 2012, 3:42
Hi
I found your emails in junk folder for some reason.
Replying now :-)
Sean
Users browsing this forum: Google [Bot] and 206 guests
