 Post subject: seagate momentus 7200.4 serial ata disk drive 320 gb
PostPosted: December 9th, 2011, 9:18
i have a seagate momentus 7200.4 serial ata disk drive of 320 gb.
yesterday i was connecting it with sata to usb cable to use as an external hdd but due to cable fault its logic started smelling.
i oppened that and found that one component in black color is burned its number is KE8. now the hdd is not spinning.
tell me that it can be repaired?
details of my hdd is:
seagate monentus 7200.4
serial ata disc drive 320 gb
model no: ST9320423AS
PART NO: 9HV14E-020
SERIAL NO: 5VH0HKZH
FIRMWARE: 0003HPM1
SITE CODE: WU
PCB STICKER: 100537087 K K010CCGU
PCB NUMBER: 100585308 REVA
WWN: 5000C5001BD6B7C3
CT: 2ARFH0183Y0ZF9
NBPC: 515659-001
 Post subject: Re: seagate momentus 7200.4 serial ata disk drive 320 gb
PostPosted: December 9th, 2011, 13:10
If you accept the risks of DIY recovery attempts, then search the forum for "TVS" and you can read many posts / info on this topic.
PostPosted: November 22nd, 2012, 9:11
ST9320423AS. attached pls find a faulty drive. the upper head lookes like broken or missing from factory.are ther 2 kinds of this disk, seagate's site says heads 3/4.
is there a way to identify no of heads with part no, or somethng else?
may we use a donor drive heads with 4 heads?. pending other parameters are the same?
tks
Ephraim
PostPosted: November 22nd, 2012, 9:34
Ephram,
Yes, you can use 4 heads to replace a 3 head drive. In fact, it is usually easier to find a 4 head donor that matches than a 3 head donor which may or may not have the same missing head.
Good luck.
PostPosted: November 22nd, 2012, 10:53
tks a lot lcoughey
PostPosted: November 23rd, 2012, 3:34
AIUI, the third character in the serial number codes for the number of heads or platters.
However, in your case this is moot.
PostPosted: November 23rd, 2012, 6:21
tks a lot fzabkar.
"AIUI" - what does it mean?
moot - what does it mean?
tks again
ephraim
PostPosted: November 23rd, 2012, 6:32
AIUI - as I understand it
moot - "Of no practical importance; irrelevant"
The point is moot in this case because you've been advised that a 4-head donor will be suitable for your 3-head patient, so it doesn't matter which donor you get.
PostPosted: November 23rd, 2012, 7:08
tks again fzabkar
Users browsing this forum: Google [Bot], runner978 and 55 guests
