Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: The death of WD ROM recovery tool: U instruction
PostPosted: December 6th, 2012, 3:49
Function: through instruction restores normal brush to write ROM program; the scope of application: ROM program embedded in the main control chip MCU series of hard disk ( eight feet ROM chip drive circuit board ); principle: short circuit drive circuit board CPU specific foot position, Using special software, via the serial port, reflash the internal or external ROM( not data line hard circuit board ) to the CPU sends an activation command and ROM data, enable the CPU ROM program resumed control of hard work.
Method of use: to install: NET4.0,13XX series circuit board in circuit board E112 plus 3.3V voltage, connected with the serial port communication line, then drive power supply ( not connected with the data line ): run U commands, COM export, call, the following SSS is connected, the selected file, writing brush, so simple.
UCommand.rar [116.29 KiB]
Downloaded 4739 times
 Post subject: Re: The death of WD ROM recovery tool: U instruction
PostPosted: December 16th, 2012, 14:44
thanks alot
but i want explaining about how to connect pcb with serial port ?
PostPosted: December 17th, 2012, 1:17
justin_123 wrote:
thanks alot
QQ370909447
PostPosted: December 21st, 2012, 10:37
Banned User
I don't understand what does this tool?
:shock:
Western digital can be hooked to a serial port as Seagate hdd?
PostPosted: December 21st, 2012, 11:34
Here is what he's saying
1. Take WD PCB(ARM based) that has erased or incompatible ROM image (bricked PCB)
2. Connect serial port as shown
3. Short some magic pins to start X-Modem sequence in MCU boot code(E112 and 3.3V for PCB 13xx, 1335 for example). The number is etched on PCB as 2060-701335-xxx
4. Select correct ROM image file and flash it to the drive with the program. Program will use special loaders (called EraseL.dll, SystemL.dll) to do so
5. Per my understanding, provided utility supports only 128KB flash files (external flash chips). For 192KB flash the program will look for Erase.dll and System.dll files that are not provided, thus will not work with those.
PostPosted: December 21st, 2012, 12:41
Banned User
Can this work also with pcb 2060-701477-002 ?
Also, in point 4 you say "Select correct ROM image file and flash it to the drive with the program". Where do i get the correct ROM file if my is erased?
PostPosted: December 21st, 2012, 13:27
Agree with you here
and wanted to add: There are many ROUTES to the SAME destination
and 4 sure, this is one of them.
but @ the end of this, something good came up here
:wink:
PostPosted: December 22nd, 2012, 11:07
Agree with you here
:wink:
PostPosted: December 22nd, 2012, 11:10
PostPosted: December 22nd, 2012, 22:01
I tried it on a ATLANTIS PATA with erased ROM (thanks to SD tools) and it didnt work.
PostPosted: December 23rd, 2012, 2:55
The trial version only hosted 13XX series motherboards, the registered version supports 13XX, 14XX, 15XX series motherboards. More please contact QQ370909447 technical Street
PostPosted: December 23rd, 2012, 20:43
Actually do I need to
for your utility ?
PostPosted: December 23rd, 2012, 22:57
What is "QQ370909447 technical Street"?
PostPosted: December 24th, 2012, 4:01
QQ is equivalent to MSN for China, very popular.
PostPosted: December 24th, 2012, 4:39
Never heard of it but figured it sounded like some ICQ messenger spin off.
PostPosted: December 28th, 2012, 15:33
Jtag -taxis!
WDmarvel
PostPosted: January 18th, 2013, 10:38
we need aphoto to com plese
PostPosted: January 19th, 2013, 1:45
PostPosted: January 19th, 2013, 1:46
PostPosted: January 19th, 2013, 2:13
http://www.drthdd.com/drte/index.htm
Users browsing this forum: No registered users and 42 guests
