 Post subject: Seagate 7200.11 ST3500320AS problem after head swap
PostPosted: December 24th, 2012, 8:41
Hello friends,
I have Seagate 7200.11 ST3500320AS with broken heads. It looks like simple case.
I swapped heads to new one from compatibility drive (I think it is compatible ;) ) I can read data from H1 and H2 without ANY problem. From H0 and H3 data is read but TERRIBLY slow.
Heads worked fine when i back them to donor. I try swap both magnets too, top magnet only, bottom magnet only, nothing change.
I think it is quite popular problem with Seagate .10, .11 and .12. I have few cases like this. If anyone manage with this problem and could share this info I will be grateful. PM is enough.
 Post subject: Re: Seagate 7200.11 ST3500320AS problem after head swap
PostPosted: December 24th, 2012, 16:19
I think you better continue reading it, even though its very slow.
www.datarecoveryne.com
PostPosted: December 24th, 2012, 18:21
Yes, but it goes REALLY slow. It can take about 3-5 months to read it. I'm sure it is heads issue with compatibility. Surface is fine, SA is fine.
PostPosted: December 25th, 2012, 2:13
Even with headmap? (clone first the working heads that read fast then the remaining). Otherwise I would try first another headstack then move pack and heads to another chassis, rather than playing with SA...
PostPosted: December 25th, 2012, 5:49
Yes, even with headmap... I try two different headstack. I clone from two heads first with normal speed. Then from two others, but it goes very slow. Heads are ok, when I put them back to donor they work very good with nominal speed.
PostPosted: December 25th, 2012, 7:15
I'll pm you later today.
Meanwhile, have a merry Xmas.
PostPosted: December 26th, 2012, 15:46
Mery Christmass :)
I will wait for PM.
PostPosted: December 27th, 2012, 4:15
Is it possible it could be the pending bug?
PostPosted: December 27th, 2012, 4:27
NO.
PostPosted: December 27th, 2012, 4:40
BlackST wrote:
NO.
And the argument for this accurate answer is the fact that two heads out of four are reading perfectly.
PostPosted: December 27th, 2012, 4:55
terminal output?
PostPosted: December 27th, 2012, 5:11
northwind wrote:
terminal output?
Rst 0x20M
(P) SATA Reset
PostPosted: December 27th, 2012, 6:26
Are there no output messages when imaging the slow heads?
Did you enable the option where full report is shown on terminal?
PostPosted: December 27th, 2012, 7:34
No, there is no output while reading. At this moment I read this drive about ~15 mln/24h so don't want interrupt until reads.
PostPosted: December 27th, 2012, 12:30
Did you tried with other destination drive?
Users browsing this forum: Google [Bot] and 235 guests
