 Post subject: Overlay file read bad
PostPosted: December 28th, 2012, 8:59
Samsung M8E (donor) after some hot swap i wanted to restore the drive, so i saved into himself all his modules.
After that, the hdd stay in Busy state endless.
any clue?
(see attached terminal)
wah.txt [740 Bytes]
Downloaded 559 times
 Post subject: Re: Overlay file read bad
PostPosted: December 28th, 2012, 9:04
Did you restore native SA to all available SA copies?
PostPosted: December 28th, 2012, 9:19
Prima di tutto, cosa stai usando ? (pc3000, SD...)
What are you using?
PostPosted: December 28th, 2012, 9:28
Pc3k and restored all 3 copies.
PostPosted: December 28th, 2012, 9:47
positivebit wrote:
any clue?
yes
Always check how drive wrote it before re-powering
PostPosted: December 28th, 2012, 11:28
Ditto.
Most probably either it is not writing correctly OR writing to WRONG locations :mrgreen:
PostPosted: December 28th, 2012, 14:25
Thanx Doomer & BlackST, reading modules after saving them, show that not modules are fine, so i believe i must find the way to save them in correct position acting on modules table or something like that..
PostPosted: December 28th, 2012, 15:03
You should already have module table , unless it is corrupted (all copies ?!?) .
PostPosted: December 29th, 2012, 3:43
I agree about modules, but service tracks do not need a position, so i wrote all tracks in all copies, and drive still show Overlay file read bad.
must be something different.
PostPosted: December 29th, 2012, 8:18
Non fidarti . Non รจ un Seagate !
It's not a Seagate, don't trust it.
Users browsing this forum: No registered users and 76 guests
