Forum rules
 Post subject: ST3160215AS LDR File needed
PostPosted: January 3rd, 2013, 2:25
I have a Seagate ST3160215AS hdd, hdd running smooth no sound but showing busy only.....and I need the LDR file do work on it. I have attached the terminal report also.
Any help is appreciated....
ST3160215AS.txt [26.7 KiB]
Downloaded 765 times
 Post subject: Re: ST3160215AS LDR File needed
PostPosted: January 3rd, 2013, 4:16
How do you plan on using this loader? Do you have the right tools and know-how?
Also, this post is in the wrong section of the forum, I believe.
PostPosted: January 3rd, 2013, 6:14
We are working on PC3000.....we try to access the hdd data but no success we got and I contact to Technical Support of PC3000 they said try to access with the loader file......
PostPosted: January 5th, 2013, 4:33
n what is the pc3000? :?:
