 Post subject: Model : ST31500341AS
PostPosted: January 5th, 2013, 13:11
Hello Gurus
i have following hdd
Serial : 9VS372TK
Firmware : CC1H
Capacity : 1 397.27 GB (2 930 277 168)
It was in busy state.
i tried busy state solution and it resolved
but if i tried partition analysis ,showing data green Z icon (pic attached)
this hdd is attached as secondary (as i discussed with customer he said no encryption,no raid,no hdd password)
So please guide.
 Post subject: Re: Model : ST31500341AS
PostPosted: January 5th, 2013, 15:41
How was the drive used by the customer? In an external? What kind of system? Any other details?
PostPosted: January 5th, 2013, 23:27
Its internal HDD .Connected secondary HDD for data storage(with single partition on win XP)
Even if i tried raw recovery its shows data but unable to open
PostPosted: January 6th, 2013, 6:23
Can you read LBA's all the way to the end of the drive?
PostPosted: January 6th, 2013, 6:41
yes i can read
PostPosted: January 6th, 2013, 7:40
DRCP wrote:
yes i can read
when u tried RAW did you get working JPG`s (for example) or all damaged?
(since i hate seagate, i prefer in such case to CLONE IT) then do whatever you are doing)
IF jpg`s are ALL DAMAGED IN RAW, i can think only of 1 things = ur client.
good luck
PostPosted: January 6th, 2013, 7:44
Clone it as per einstein9's sensible suggestion.
Then scan it with other recovery sw such as rstudio, UFS explorer, GDB etc...
PostPosted: January 6th, 2013, 11:06
problem resolved thanks gurus
PostPosted: January 6th, 2013, 11:13
What was the issue?
PostPosted: January 6th, 2013, 11:34
i again discussed with customer ,he said that drive is compressed drive.
initially just i tried raw recovery and checked some jpg files which was currupt.
then i found Z represents for zip so i recovered some folders which was dcm files so cant open with regular viewer its showing corrupt files (due to that reason i confused and whole hdd contains only dcm files)
then i installed DCM viewer and checked data .(all ok)
thanks gurus for kindly help specially labtech,pcimage & einstein9 (the super gurus helping us )
