Forum rules
 Post subject: SCSI newbie trying to issue SCSI "MODE SELECT"
PostPosted: January 15th, 2013, 20:57
I'm trying to issue a MODE SELECT, and am getting SK/ASC/ASCQ == 5/0x26/0
[ILLEGAL REQUEST / INVALID FIELD IN PARAMETER LIST].
There are so many ways to obtain that result... I'd love someone to review what I've got, to knock out any trivial problems. Thanks in advance:
Platform: FreeBSD 9.0
Controller: Adaptec 51645
Software: in-house HDD control software
I'm successfully issuing MODE SENSE, with the following results:
PS=1; SPF=0; PC=0x8; LEN=18
DEFAULT MODE PARAMS:
0000: 14 00 ff ff 00 00 00 00
0008: ff ff 80 08 00 00 00 00
0016: 00 00
CURRENT MODE PARAMS:
0000: 10 00 ff ff 00 00 00 00
0016: 00 00
I see that the 'WCE' (write cache enable) bit is not set in current page, but is on default page. One might presume it's supported, and it's desirable to have it enabled. I issue the following MODE SELECT:
CDB: 55 10 00 00 00 00 00 00 1c 00
DATA:
0000: 00 00 00 00 00 00 00 00
0008: 08 12 14 00 ff ff 00 00
0016: 00 00 ff ff 80 08 00 00
0020: 00 00 00 00
and obtain: SK=0x5; ASC=0x26; ASCQ=0x0
Anything obvious?
 Post subject: Re: SCSI newbie trying to issue SCSI "MODE SELECT"
PostPosted: January 15th, 2013, 22:59
You forgot the page code(8) in CDB2
I'm also not sure why you using LLBA bit in CDB1
PostPosted: January 15th, 2013, 23:12
Clarify, my bad: these are MODE SENSE (10) and MODE SELECT (10).
LLBAA is on the MODE SENSE;
bit in similar position on MODE SELECT (10) is "PF".
Regardless, I did find a problem elsewhere - and it's working just fine now. Thanks for your eyes!
PostPosted: January 16th, 2013, 10:21
Right, sorry for misleading you
