 Post subject: WD2500JD-75HBC0
PostPosted: January 17th, 2013, 3:04
Hello everyone, I'm a new member here.
I have a drive that won't spin up. Tried connecting different power supplies to it and nothing. put my ear against the drive and connect power. it's silent.
MDL: WD2500JD-75HBC0
DATE: 10 MAY 2005
DCM: DSCHCTJAA
PCB sticker: 2061-701267-200 AK
PCB print: 2060-701267-001 REV A
Should I replace the PCB and swap U12?
I've found a couple of drives that are close matches but not exactly. For PCB swap, which one of these is the best match:
donor drive 1:
DATE: 23 SEP 2005
DCM: DSBHCTJAH
PCB sticker: 2061-701267-200 AM
doner drive 2:
DATE: 10 MAY 2005
DCM: DSBACTJAH
i'm waiting for the owner to send the PCB numbers.
Thanks in advance!
 Post subject: Re: WD2500JD-75HBC0
PostPosted: January 17th, 2013, 3:35
Yes, swap PCB and move U12
Donor 1 will be fine.
DISCLAIMER: BEWARE THAT FURTHER DAMAGE MAY BE PRESENT AND YOU ACCEPT ALL RISKS OF DIY, YOU COULD DESTROY YOUR DATA FOR GOOD.
PostPosted: January 17th, 2013, 3:36
The pcb from donor 1 is ok to use, you also need Rom replacement.
http://www.rescue-it.se
PostPosted: January 19th, 2013, 21:19
Thanks for the help.
I managed to find a donor drive with identical manufacture date and PCB numbers.
Should I attempt to power up the drive without moving U12? Any risk of damage to
the drive?
PostPosted: January 20th, 2013, 0:50
i'm happy to report that the PCB swap worked. no ROM swap needed. Thanks!
PostPosted: January 20th, 2013, 9:19
Great!
You got real lucky, do the lottery!
PostPosted: January 20th, 2013, 18:18
The donor was close enough.
Well done :)
Users browsing this forum: No registered users and 286 guests
