 Post subject: How to play .nvr files
PostPosted: January 22nd, 2013, 9:49
Hello Everybody
I have recovered CCTV footage from a DVR & want to play it on pc ,I tried to search for playback tool ,but could not locate one. Customer gave me only hard disk so I dont know make of DVR as well.
I would like to know how to play .nvr files. Thank you
 Post subject: Re: How to play .nvr files
PostPosted: January 22nd, 2013, 12:26
you can try this, not sure it will work tho...
http://www.softpedia.com/get/Multimedia ... ayer.shtml
PostPosted: January 22nd, 2013, 12:41
Online
How about VLC?
ACELab partner
PostPosted: January 23rd, 2013, 3:54
Hi pclab and cleanroom. Thanks for suggestion.
Unfortunately both VLC & NVR player does not support this files ( NVR player supports avi files only)
Forensic Innovations latest FI Find File V 2.37 ( having signatures of more than 4000 file types has failed to identify these files.
PostPosted: January 23rd, 2013, 6:37
post here the header from winhex & will see
Edited, FYI, DVR`s record RAW Data
PostPosted: January 23rd, 2013, 7:28
Thanks a lot einstein9
attached is snapin winhex as well as file blocks,hope to get it decoded.
nvr.txt [566 Bytes]
Downloaded 685 times
PostPosted: January 23rd, 2013, 9:04
i`ve tried my DVR Player on many other brands (playing those RAW) and worked
but the problem is mine is Licensed which cannot share with others (comes with the PSS App.)
and your file here is supported (tested it before and wrote my note about the header)
the question for you now is HOW?
:cry:
PostPosted: January 23rd, 2013, 14:10
Thanks einstein9
PostPosted: January 23rd, 2013, 14:29
einstein9,
I was wondering if you are willing to share the name of the DVR player name.
Recently I was assigned a case to recover a hdd with CCTV footage in it, but I couldn't obtain the actual DVR.
Thanks for sharing.
Terry
PostPosted: January 25th, 2013, 0:59
Update for this case
These files does not contain any audio /video Data.They are indexing files created by DVR to keep track of sectors used.
This could be useful for everyone doing dvr related recovery
PostPosted: February 4th, 2013, 3:31
Regret I was completly wrong in analysing these files. My earlier conclusion is wrong.
.nvr files indeed hold large data.They are actually .264 files.
PostPosted: February 4th, 2013, 5:17
and RAW recording data
Users browsing this forum: No registered users and 67 guests
