 Post subject: Need LDR for WD3200AAJS-00B4A0
PostPosted: January 23rd, 2013, 5:22
Hello everybody
I have a WD drive with the following data printed on it:
WD 320 GB Caviar SE
WD3200AAJS-00B4A0
DCM: EHNNNT2CB
R/N: 701537
LBA: 625142448
WWN: 50014EE05606307E
on PCB:
on Board: 2060-701537-003 REV A
Sticker on board: 2061-701537-G00AC XW6D05 V78F 6 0005430 8435
Using PC-3000 UDMA, I get firmware version
Firmware version........................ : 0005006Q
SA dir reading.......................... : Ok
SA Copies avalabled..................... : NONE
Configuration reading................... : No SA copy avalabled
Has anyone LDR for this model/firmware?
Costas
 Post subject: Re: Need LDR for WD3200AAJS-00B4A0
PostPosted: January 23rd, 2013, 18:42
Look there
PostPosted: February 6th, 2013, 9:12
Kamen wrote:
Look there
Unfortunately, I could not find anything there.
The WD3200-00B4A0 had a totally different firmware on 11.rpm module.
I tried to upload the LDR and I got a 'ERRO not compatible'.
The closest 11.rpm I could find was 00050067 from a different model, and it was not loading again with the same error (I guess that was reasonable).
Anyone has or can direct me to where to find 11.rpm v 0005006Q for WD3200AAJS-00B4A0?
Thank you very much
Costas
PostPosted: February 6th, 2013, 10:14
:idea: good luck
11.rar [135.9 KiB]
Downloaded 356 times
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: February 11th, 2013, 4:58
Hello dear GURUS
I need firmware for WD3200AAJS-00B4A0 firmware version 0005006Q. (I use PC-3000).
Anyone having this?
Please reply or PM me.
Thank you in advance
Users browsing this forum: Majestic-12 [Bot] and 56 guests
