 Post subject: Looking for HTS543232a7a384 firmware or module
PostPosted: January 24th, 2013, 7:26
Hi all,
I'm looking for firmware or module WRT0 for this drive.
Thank you,
Terry
 Post subject: Re: Looking for HTS543232a7a384 firmware or module
PostPosted: January 24th, 2013, 9:02
Just about every Hitachi drive reports that module with error.
It is not important for the drive's operation, UNLESS there is something else you are not telling about.
PostPosted: January 24th, 2013, 15:29
labtech,
Am able to bring up this drive, but I can't perform a resource back up nor SA test.
Basically, I just need to replace this module (so i can access it) and zero it out.
Terry
PostPosted: January 24th, 2013, 15:46
terryko68 wrote:
labtech,
Sorry, maybe I am misunderstanding or I do not know what I am talking about, but I do not see the logic in doing that.
If there is something that would prevent SA access as far as reading modules, then it would have to be the SA marker module. But then, if that was the case, how can you possibly have had read the WRT0 module?
Even that in itself is strange, that can't read any other module but WRT0.
I do not understand. Leaving it alone... Best wishes.
Edit: are you in the right family in the utility?
