 Post subject: Toshiba MK7559GSXP wont spin up
PostPosted: January 24th, 2013, 17:29
Hello
I have this hdd that wont spin up. Its not recognized in windows either.
MK7559GSXP HDD2J51 E UL01 S is the model number.
I ordered a replacement pcb from eBay but to no effect.
The hdd tries to spin up, but then resets its motor and tries to spin up again. The laptop it was in fell down.
Im charging the camera and will post pics.
 Post subject: Re: Toshiba MK7559GSXP wont spin up
PostPosted: January 24th, 2013, 17:47
99% stiction. The heads are stuck to platter caused by the drop. If the data is important i would get a pro to look at it and he may be able to do it for a low cost if the reading heads are not damaged.
Just swapping Toshiba boards will not work anyways, so put the old board back since it is probably fine.
stop spinning it up too... if the heads are stuck you could cause more damage by turning it on over and over again.
PostPosted: January 24th, 2013, 18:01
Thanks for the advice. I will have it looked at tomorrow.
PostPosted: January 26th, 2013, 0:28
We currently have one in the shop. It was "probably" dropped and the heads were stuck onto the platter. The heads were also damaged in a way that they would ruin the platters if not replaced.
http://www.datasaversllc.com
PostPosted: January 28th, 2013, 18:43
What do you guys figure on stuff like this ? I have access to a cleanroom and i could order a donor drive off ebay..
http://www.youtube.com/watch?v=uIPZtJyrVPw
PostPosted: January 29th, 2013, 4:21
Negative.
I can smell bad news from down here.
Users browsing this forum: pepe and 323 guests
