 Post subject: DiamondMax22 STM3320614AS fw MC1H - 0LBA issue
PostPosted: January 28th, 2013, 11:28
Banned User
Hello, i've this DiamondMax22 STM3320614AS hdd with firmware MC1H.
The drive is no more detected in windows, bios detects it with 0 LBA.
No clicking sounds, motor spins good and terminal gave me successfully spin down and spin up.
PCB seems to be ok, no burning signs and no oxidation.
I tried to do the translator regeneration in terminal but nothing has changed, still detected with 0 LBA in bios and in MHDD.
I tried again but this time i did also SMART reset which gave me LED:000000CC FAddr:00239CED error
Terminal log:
ASCII Diag mode
F3 T>m0,2,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 2DF8
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Zone re-format was skipped.
F3 T>/1
F3 1>N1
Init SMART Fail
MHDD log:
[PRE]
51 ERR INDX CORR DREQ DRSC WRFT DRDY BUSY        AMNF T0NF ABRT IDNF UNCR BBK 04
[MAXTOR STM3320613AS   ] [            0] [             ] [                   ]
MAXTOR STM3320613AS  LBA:0  BIOS: 81H
SN:9SZXXXXX   FW:MC1H   CACHE:16384KB   Size = 0MB
IMPORTANT NOTICE:  This device does not
support LBA mode. MHDD will NOT work with this device.
Init drive: [RECAL]
RECAL FAIL
This drive does not support LBA mode or not detected.
SN:9SZ2LN7W   FW:MC1H   CACHE:16384KB
Supports: LBA48 HPA AAM DLMC LBA MS16 DMA (UDMA6,MWDMA2)
SMART: Enabled SelfTest: Supported ErrorLog: Supported
Security: high, OFF. Size = 0MB
| MHDD 4.6 (c) Dmitry Postrigan | FREEWARE                          | 14:36:32
[/PRE]
Is MC1H the last fw update for this drive?
I found on seagate site this:
http://knowledge.seagate.com/articles/e ... Q/207975en
Maybe MX1B is the last, but i can't understand because if i clic on button "Which firmware is right for me?" it answers "No Newer Firmware Available"
Please help me to understand this, and if this issue is caused by firmware crash or something else.
Thank you.
 Post subject: Re: DiamondMax22 STM3320614AS fw MC1H - 0LBA issue
PostPosted: January 28th, 2013, 11:48
ABC of data recovery : TRANSLATOR...
PostPosted: January 28th, 2013, 11:56
Banned User
Yes :P
Can you help me to understand were is the problem?
Could it be the pcb? Or you think more like internal problem?
PostPosted: January 28th, 2013, 12:22
Banned User
If translator regeneration doesn't solve the 0 LBA issue, could it be a problem with checksum value of the p-list?
PostPosted: January 28th, 2013, 12:30
would having a read out of his slip list help? Maybe the factory specific section of his hard drive is corrupt?
DISCLAIMER: I wouldn't try dumping that info until the regulars have had a chance to explain how bad of an idea it is or how stupid I am for suggesting it. After you read all of that then maybe you want to try it, or maybe you just want to "bin it" haha
PostPosted: January 28th, 2013, 13:47
Banned User
Why SMART reset fails?
Can i still do something or this is a case for DR?
PostPosted: January 28th, 2013, 15:39
I think this is dead? I wish I knew more so I could help you out.
PostPosted: January 28th, 2013, 16:18
Time for Pro DR, and don't fiddle with the drive anymore, could end up with a bricked one for sure.
http://www.rescue-it.se
PostPosted: January 29th, 2013, 7:19
Banned User
Ok i will ship it to a pro DR, but i want to know if MC1H is the last firmware or if is MX1B ?
PostPosted: January 31st, 2013, 13:07
Banned User
This should not be a diffcult question to answer, right?
A guru should know this... :roll:
PostPosted: January 31st, 2013, 15:43
It's MX1B
PostPosted: February 4th, 2013, 9:39
Banned User
Spildit wrote:
- Block read channel
- Spin down drive (PCB)
- Unblock read chanel
- Spin Up drive
- Go to /1 and erase SMART
- Remove power to HDD and start it again without blocking the read channel and with PCB, etc ...
- Go to T and erase G-List (i4,1,22)
- Power off HDD again, Power it on, go to T and do the m0,2,2,0,0,0,0,22 . Check to see if it states something like :
How do i block the read channel?
I already tried with piece of paper under the head contact, but i always get LED:000000CC on smart reset comand.
Tried also with paper under the motor contact and both, but i always get LED:000000CC
Maybe the trick is to turn off the read channel as you say, but how?
PostPosted: February 5th, 2013, 12:26
Banned User
Spildit wrote:
Put the plastic on the spindle contacts, turn on the drive, issue the spin down command, remove the plastic, issue the spin up command, go to /1 and erase SMART. If it doesn't work assume it's not a DIY case and send the drive to a pro to pr4event further damage.
I put the piece of plastic under the spindle contact, but i don't get the terminal prompt, ^Z doesn't work.
I get into F3 T only with all pcb connected to the drive.
Tried again the N1 but i get always the same LED CC error.
I tried also N5, N6 and ^U, maybe you can understand what's wrong:
ü
Rst 0x10M
ASCII Diag mode
F3 T>/1
F3 1>N6
Att  Thresh
  1      6
  3      0
  4     14
  5     24
  7     1E
  9      0
  A     61
  C     14
B8     63
BB      0
BC      0
BD      0
BE     2D
C2      0
C3      0
C5      0
C6      0
C7      0
F0      0
F1      0
F2      0
  0      0
  0      0
  0      0
  0      0
  0      0
  0      0
  0      0
  0      0
  0      0
F3 1>N5
Att
Num  Flgs normlzd worst raw
0   0000    0      0   00000000000000
F3 1>/
F3 T>
-------------------> '^U comand'
       00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
0000: C8 05 00 00 00 08 53 43 88 00 00 00 01 10 01 00
0010: 00 00 00 00 00 00 0F 00 01 00 0A 00 A2 00 00 00
0020: 03 00 16 00 AE 00 00 00 04 00 16 00 C6 00 00 00
0030: 07 00 0A 00 DE 00 00 00 08 00 12 00 EA 00 00 00
0040: 0A 00 0A 00 FE 00 00 00 1A 00 0A 00 0A 01 00 00
0050: 3A 00 36 00 16 01 00 00 3C 00 3E 00 4E 01 00 00
0060: 00 00 42 00 8E 01 00 00 5C 01 0C 00 D4 01 00 00
0070: 7C 01 24 00 E4 01 00 00 7C 02 0C 01 0C 02 00 00
0080: 7C 03 38 01 1C 03 00 00 3E 00 70 01 58 04 00 00
0090: 38 05 00 00 01 10 00 00 00 00 00 00 FF FF 01 00
00A0: 81 0A C0 10 FF 00 00 00 05 00 FF FF 83 16 00 01
00B0: 00 00 00 00 00 02 00 03 02 00 00 01 00 00 00 00
00C0: 40 00 00 00 84 16 00 00 04 02 00 00 00 00 00 00
00D0: 00 00 00 00 00 00 00 00 1C 20 00 00 87 0A 00 10
00E0: FF 00 00 00 00 00 FF FF 88 12 14 00 FF FF 00 00
00F0: FF FF FF FF 80 20 00 00 00 00 00 00 8A 0A 02 00
0100: 00 00 00 00 00 00 00 00 9A 0A 00 02 00 00 00 05
0110: 00 00 00 04 BA 36 00 05 00 00 00 00 00 08 00 00
0120: 00 00 00 00 31 08 08 08 00 05 44 02 00 00 00 00
0130: 00 00 08 00 01 08 08 08 08 00 00 00 01 02 13 88
0140: 03 E8 00 64 00 00 00 00 00 00 00 00 BC 3E 00 70
0150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0160: 00 00 00 00 80 00 00 78 00 C8 00 00 00 00 00 00
0170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0180: 00 00 00 00 00 00 00 00 00 00 00 00 80 42 30 32
0190: 37 4A 4A 30 44 54 58 20 20 20 20 20 20 20 00 00
01A0: 00 00 00 00 53 54 33 33 32 30 36 31 33 41 53 20
01B0: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
01C0: 20 20 20 20 20 20 20 20 20 20 20 20 01 00 08 00
01D0: DC 01 0C 00 01 00 00 18 00 18 00 00 00 00 00 00
01E0: FC 01 24 00 00 11 11 11 11 11 11 11 12 11 11 11
01F0: 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11
0200: 11 11 11 11 10 00 00 00 FC 02 0C 01 00 00 00 00
0210: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0220: 00 00 00 00 00 00 00 00 80 00 00 00 F2 E8 80 00
0230: 00 A0 80 00 80 00 00 00 F2 E8 80 00 00 A0 80 00
0240: 80 00 00 00 F2 E8 80 00 02 A0 80 00 80 00 00 00
0250: F2 E8 80 00 00 A0 80 00 80 00 00 00 71 C8 80 00
0260: 00 A0 80 00 80 00 00 00 71 C8 80 00 00 A0 80 00
0270: 80 00 00 00 F2 E8 80 00 00 A0 80 00 80 00 00 00
0280: F2 E8 80 00 00 A0 80 00 00 00 00 00 11 C8 80 00
0290: 00 A0 80 00 80 00 00 00 F2 E8 80 00 00 A0 80 00
02A0: 80 00 00 00 F2 E8 80 00 00 A0 80 00 00 00 00 00
02B0: 00 00 00 00 00 00 00 00 80 00 00 00 F2 E8 80 00
02C0: 00 A0 80 00 80 00 00 00 71 C8 80 00 00 A0 80 00
02D0: 00 00 00 00 F2 C8 80 00 00 A0 80 00 00 00 00 00
02E0: 00 00 00 00 00 00 00 00 80 00 00 00 71 C8 80 00
02F0: 00 A0 80 00 00 00 00 00 00 00 00 00 00 00 00 00
0300: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0310: 00 00 00 00 00 00 00 00 FC 03 38 01 00 00 00 00
0320: 00 05 80 00 00 00 00 00 00 00 00 00 00 00 00 00
0330: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0340: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0350: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0360: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0370: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0380: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0390: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
03A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
03B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
03C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
03D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
03E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
03F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0400: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0410: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0420: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0430: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0440: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0450: 00 00 00 00 BE 00 70 01 FF 3F 10 00 3F 00 04 00
0460: 10 00 00 02 00 02 FF 3F 10 00 3F 00 10 00 07 7F
0470: 03 00 78 00 78 00 78 00 78 00 1F 00 0E 05 00 00
0480: 48 00 40 00 F0 01 29 00 6B 34 01 7F 63 41 69 34
0490: 01 BE 63 41 00 00 FE FE FE FF 00 FE 00 00 00 00
04A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01
04B0: 00 00 0E 40 08 40 08 10 00 00 01 00 0F 00 06 00
04C0: 03 00 00 00 32 00 14 00 33 00 24 00 0F 00 1E 00
04D0: 32 00 00 00 13 00 61 00 32 00 14 00 32 00 00 00
04E0: 3A 00 00 00 22 00 2D 00 32 00 00 00 32 00 00 00
04F0: 32 00 00 00 22 00 00 00 1A 00 00 00 12 00 00 00
0500: 10 00 00 00 3E 00 00 00 32 00 63 00 32 00 00 00
0510: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0520: 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0530: 00 00 00 00 00 00 3F 10 37 3C 0A 0E 07 00 00 00
0540: 00 00 00 00 80 00 01 00 01 00 00 00 00 00 00 00
0550: 00 00 00 00 00 00 00 00 00 00 00 00 40 04 00 15
0560: 20 00 2C 01 00 00 00 00 80 A0 00 38 00 3F 00 00
0570: FF FF 00 00 00 00 00 00 00 00 00 00 4B 00 00 00
0580: 00 00 00 00 54 15 3C 00 02 00 00 00 00 00 00 01
0590: 00 08 05 00 00 00 01 0A 00 00 00 00 00 00 00 00
05A0: 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00
05B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
05C0: 00 00 00 00 00 00 00 00
           DriveNativeInfo Mode Page
              DriveNativeInfo Group
Byte:018E:       PartNumber = 30 32 37 4A 4A 30 44 54 58
                 '027JJ0DTX'
Byte:0197:       PartNumberWhitespacePad = 20 20 20 20 20 20 20 00
Byte:019F:       PartNumberPad = 00
Byte:01A0:       ProcessControlVersion = 00 00
Byte:01A2:       CongenConfigurationState = 00
Byte:01A3:       WrittenCount = 00
Byte:01A4:       InternalSeagateModelNumber =
                 53 54 33 33 32 30 36 31 33 41 53 20 20 20 20 20
                 'ST3320613AS                             '
Byte:01CC:       BuildFlags = 01 00
Byte:01CC:           Bit:0, QNR_SUPPORTED = 1
Byte:01CE:       RealTimeUpdatedFlags = 08 00
Byte:01CE:           Bit:3, CONGEN_READ_FROM_MEDIA = 1
ASCII Diag mode
F3 T>
PostPosted: February 7th, 2013, 16:02
Banned User
It's normal Num Flgs normlzd worst raw is all "0" ?
F3 1>N5
Att
PostPosted: February 8th, 2013, 12:07
Banned User
As i can see there are many drives with translator problem
PostPosted: February 8th, 2013, 12:08
Banned User
DiamondMax 22 are the same of Barracuda 7200.11.
DM22 have busy and 0LBA bug as 7200.11 and easily fixable with N1 and m0,2,2,,,,,22 commands.
But this solution doesn't work on this DM22, meaby because of the strange firmware MC1H :?
If firmware was MX15 maybe it would work :roll:
PostPosted: February 9th, 2013, 16:55
After that you have to rebuild something else more than translator and P-list, I'm afraid :mrgreen:
