 Post subject: toshiba mk3265GSX spins up but BIOS hangs on it ?
PostPosted: February 12th, 2013, 13:45
hello friends ,
i have a Toshiba MK3265GSX , when powered up it spins but with lower spin noise compared to similar drive .
when connecting to SATA the bios detects the other drives connected to the system but hangs on this drive .
DDI4 says drives is not responding .
i am suspecting that it's a motor related problem as the spin tune is not like "2 other similar healthy drives"
what are you saying ?
thank you
 Post subject: Re: toshiba mk3265GSX spins up but BIOS hangs on it ?
PostPosted: February 12th, 2013, 13:50
ah forgot to tell that when testing the PCB voltages along with the similar drive's PCB , both givving the same result , so i think the pcb mispowering the drive is excluded ...
PostPosted: February 12th, 2013, 13:54
Leave him work for a while.
Angel Data Recovery
PostPosted: February 12th, 2013, 14:44
thank you for the hint , but nothing new , it still spins at same rate/noise level
PostPosted: February 12th, 2013, 14:52
Are the heads moving from it's park ?
PostPosted: February 12th, 2013, 15:11
when connected to power only , i can clearly hear the heads moving out the ramp and repark again and drive continue spinning .
when connected to power + sata cable , heads leave ramp and return then leave then return and producing a sound very similar to the heads sound when u switch PCBs without moving the rom .
i do have a clean room thought , but i will open up the cover as last resort .
PostPosted: February 12th, 2013, 18:39
I would try find a healthy Pcb and replace/reprogram the ROM...to rule out Pcb first.
http://www.rescue-it.se
PostPosted: February 13th, 2013, 13:15
thank you , tried that today from a donor drive "without swapping roms" , same issue , and the first drive's PCB spinned the donor one at normal rate .
why didn't i order a platter swap tools with my heads swap ones ?!?!!
thank you
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 270 guests
