 Post subject: no respond to Ctrl + Z (seagate HDD)
PostPosted: February 15th, 2013, 14:53
Hi
some times Seagate Hdd with Busy problem do not answer to Terminal.How can I do for them?
 Post subject: Re: no respond to Ctrl + Z (seagate HDD)
PostPosted: February 15th, 2013, 17:37
7200.12?
PostPosted: February 16th, 2013, 2:19
different Model 7200.11 and 12 and also LP and Green.in some case after cleaning conectors or changing PCB or after trying several times it will be success ,but some times they do not work to doing the job.
PostPosted: February 16th, 2013, 22:46
There are various solutions specific to model drive. Some can't connect to terminal.
Using hyperterminal?
PostPosted: February 17th, 2013, 10:40
thank you Dear labtech
Yes I did , but it dose not any reply after hit Ctrl + Z nither in PC-3000 nor in Hyperterminal. it is so bad because some customer told me that HDD which you couldn't repair is ok now by someone els. :cry:
PostPosted: February 17th, 2013, 15:07
One that I could not fix?!? How would you or customer know any of this?
PostPosted: February 18th, 2013, 4:28
He means a drive HE couldn't recover was recovered by someone else. Missed the quotes.
PostPosted: February 18th, 2013, 9:33
Dear northwind
yes, you are right.
PostPosted: February 18th, 2013, 17:56
sra wrote:
Dear northwind
yes, you are right.
Sorry about that.
Don't worry, sometimes it happens. Some cases fall through cracks... Rarely, but they do.
Users browsing this forum: No registered users and 47 guests
cron
