 Post subject: Cooling the disks with fans when cloning
PostPosted: February 26th, 2013, 13:24
I saw this company cooling disks with fans when they're cloning them, like this:
How useful do you think this is? I was a bit under the impression that disks are generally meant to run at room temp. but maybe cooling the PCBs helps?
 Post subject: Re: Cooling the disks with fans when cloning
PostPosted: February 27th, 2013, 1:26
It helps. And not with the intent of cooling the PCB.
Don't necessarily need a fancy fan like that one.
PostPosted: February 27th, 2013, 9:24
I have a disk that works correctly only when operating +56'C.
PostPosted: February 27th, 2013, 10:03
i just use cheap 80mm case fans standing next to the drive to keep the airflow moving across them. works well
Users browsing this forum: No registered users and 147 guests
