 Post subject: Swap Seagate PCB , ST9320423AS PCB with ST9500420AS
PostPosted: March 6th, 2013, 11:17
Hi guys,
My Seagate 320GB, Momentus 7200.4 (model: ST9320423AS) is having problem. The motor is running but my computer couldn't detect it.
Well, I manage to found a seller online which selling Seagate 500GB, Momentus 7200.4.
Did any try to swap the PCB with different capacity of HDD? :roll:
Thanks and regards
 Post subject: Re: Swap Seagate PCB , ST9320423AS PCB with ST9500420AS
PostPosted: March 6th, 2013, 13:26
most likely not a pcb issue and no you cannot simply just swap the board. plus i am pretty sure even if you could just simply swap, those 2 are not compatible.
Users browsing this forum: No registered users and 68 guests
