 Post subject: hitachi donor ! exact match but not compatible ?!
PostPosted: March 8th, 2013, 8:56
hello ,
i had a hitachi
HTE541040G9AT00
P/N : 0A27112
MLC : DA1206
JAN 06
which died on me , while imaging using ddi4 .
so i found a donor " the guy was selling a lot of 2 hdds" donor drive specs is
HTE541040G9AT00
P/N : 0A27112
MLC : DA1206
MAR 07
the donor was testing to work 100% with the ddi .
after performing the head swap , the patient drive clicks , not getting ready .
i did reswapped the head back to the donor , and it worked smoothly again .
what is the problem ?
 Post subject: Re: hitachi donor ! exact match but not compatible ?!
PostPosted: March 9th, 2013, 0:07
This has nothing to do with FW on this one. Do you have a microscope to check your platters to see if they are damaged or scratched?
Iorana Haraharaini
PostPosted: March 9th, 2013, 5:09
Incompatible heads.
PostPosted: March 9th, 2013, 5:29
northwind wrote:
Incompatible heads.
that's the thing am afraid of :?
but matching all the above critiria should have gave a great chanse of compatibility .
thank you all for your ideas .
today i swapped the patient drive's heads with the second donor "as i bought a lot of 2 hdds that can work as a donor "
same issue , drive clicks once and then ddi shows "drive is not responding"
tried the donor pcb on the patient drive after swaping heads , a nother click with different sound . but only one click as the previous pcb .
PostPosted: March 9th, 2013, 5:34
having 14 months between the original and donor production time , has made heads not compatible , inspite of all the other specs , totally match ?
PostPosted: March 9th, 2013, 15:55
Spildit wrote:
Did you swap the NVRam too ?
Do you have some tool to start the drive using a loader file and check for module damage ?
nop , no nvram change was applied
and no tool to start the drive using a loader, why should i have concerns regarding FW modules defects ? as long as the patient drive was being imaged successfully until certain point , where it started clicking and stopped responding ?
thanks
PostPosted: March 9th, 2013, 18:42
This is very correct. The same issues are with WD drives too. What you think is a good donor is not a good donor and what you think will not work works. So this one will need a different set of heads on this one.
No you do not have FW issue, no you do not need to swap a NVRAM because you are not touching the PCB on this one. I would not regard some of the comments to you on this issue. You need to locate a different set of heads and try this one.
Iorana Haraharaini
PostPosted: March 10th, 2013, 5:28
northwind wrote:
Incompatible heads.
I second that .
@ raven4d
You can use (HTS541040G9AT) drives like donor, HTE differ only this Enhanced Availability .
And hope, you saved NV-Ram FW before setting PCB from patient to donor ( it can be blocked automaticaly , when code doesn't match with SA) .
Angel Data Recovery
PostPosted: March 16th, 2013, 7:23
my question is
what not swap platter ?
put patient platter to the donor drive ?
PostPosted: March 17th, 2013, 2:59
rooster2000 wrote:
my question is
Why?? Not all DR needs platter swap and this one sure does not need platter swap. It need heads that match so it works.
Iorana Haraharaini
Users browsing this forum: No registered users and 313 guests
