 Post subject: bitlocker damaged drive ?
PostPosted: March 10th, 2013, 10:28
hello friends ;
i have this flash disk which has been encrypted using win7 bit locker , and got " for some reason " damaged ,
i know the password and i have the recovery key .
any software to repaire the volum ? or at least recover portions of the data ?
thank you alot
 Post subject: Re: bitlocker damaged drive ?
PostPosted: March 10th, 2013, 11:40
Can you elaborate on "damaged"?
Was it formatted? Can you image the device?
What are the first few sectors showing?
Have you tried the Bitlocker Recovery Tool?
Are you running a version of Windows that supports Bitlocker?
Data Recovery Ireland
PostPosted: March 10th, 2013, 14:00
thank you for your reply
when plugged it shows the bitlocker windows telling " recovery error"
all sectors showing
UNREADABLESECTOR
using winhex
and yes i tried that tool "bd-repair" and it gave me
ERROR: The input volume has suffered damages to critical information related to the decryption key.
Please try the -KeyPackage option to specify a key package. The volume may not be recoverable.
i am using winddows 7 ultimate
PostPosted: March 10th, 2013, 16:00
raven4d wrote:
all sectors showing
UNREADABLESECTOR
using winhex
CK asked a great question, and your answer above means you are looking for the wrong problem - stop wasting time looking for a BitLocker problem. You actually have a flash problem, based on your answer above, so it's no surprise that BitLocker can't decrypt something which is unreadable. :(
If you don't have flash recovery skills, you'll need to fix / outsource that part first.
PostPosted: March 10th, 2013, 16:08
+1 Vulcan.
You have a media problem which you need to address first.
Forget about Bitlocker for the moment, that's a mere file system issue.
You need to figure out what's wrong with the flash before you worry about bitlocker.
PostPosted: March 10th, 2013, 16:53
thank you both for your help , appreciated
PostPosted: October 10th, 2015, 10:44
Raven ,
just Curious To Find If You Were Able To Repair That Drive .Seems To Me Like a Controller Issue In The Drive .What Kind of a USB Flash Drive It Was [ Monolith Or Non Monolith ]
Users browsing this forum: No registered users and 201 guests
