 Post subject: What does Reverse Clone do that normal clone mode can't?
PostPosted: March 13th, 2013, 12:48
I've always been intrigued by the concept of reverse cloning.
If for example you have a drive with a lot of bad sectors , what can it acheive that normal cloning cannot?
when it clones in reverse - it is still going to hit bad sectors right?
 Post subject: Re: What does Reverse Clone do that normal clone mode can't?
PostPosted: March 13th, 2013, 13:38
Hi again!
So on a failing drive the read cache gets all messed up - preventing a proper clone?
PostPosted: March 13th, 2013, 15:39
ok thanks for that explanation
But, if you know that BB (as per your illustration aboce) has an approx LBA of 60000000 and finishes at 80000000
You can just use your cloning utility or DR program to concentrate on
0 to 60000000
THEN
80000000 to End
without any need for reverse cloning?
PostPosted: March 13th, 2013, 15:46
ok thanks Spildit
PostPosted: March 14th, 2013, 5:06
Read Look Ahead are not possible in reverse cloning.
There is varying surface densities between start and end of disk.
Start of disk is accessed more frequently than end and more chance to develop read problems.
Repeated attempts to read damaged sectors (at start) can further damage your read heads.
Users browsing this forum: No registered users and 271 guests
