 Post subject: WD30EZRX 3TB BRICKED AND NOISE
PostPosted: March 15th, 2013, 15:53
Hello, i bought a WD30EZRX 3TB and after a power cut the hd is gone from bios and makes a sound like in loop, can anyone help me? i attached an mp3 with the sound, the beep is from the computer start not the hd.
http://www.mediafire.com/?fm525eaasjd2dwj
 Post subject: Re: WD30EZRX 3TB BRICKED AND NOISE
PostPosted: March 15th, 2013, 16:48
Your drive has a stuck motor. If there is no data of value, send it back for warranty. If the data is worth anything to you, send it to a data recovery professional for an assessment "BEFORE" you try DIY tricks that will likely make things worse.
PostPosted: March 16th, 2013, 2:39
I really dont have the money to send it to a profesional, i un bricked before a seagate barracuda i wish to learn how to repair this.
PostPosted: March 17th, 2013, 2:38
You simply can't connect a terminal and unstuck a motor on your drive. First because there's no terminal... :mrgreen:
PostPosted: March 17th, 2013, 3:12
Send in back for RMA and get a new one. If you screw around with this then you are out all the way around. You will not have a drive, data, or anything but a mess on your hands. Like everyone said this is not an easy one to do.
Iorana Haraharaini
PostPosted: March 18th, 2013, 12:21
But if he does that, there is no warranty.
Also hitting a 30EZRX will result in drilling a hole in water.
Users browsing this forum: No registered users and 109 guests
