 Post subject: WD5000AACS-00ZUB0 not detected
PostPosted: March 30th, 2013, 16:43
Drive is not detected by system. No visible damaged on PCB.
Is it worth to try replace PCB from WD5000AAVS with same PCB number.
Any advice.
Are there some measurement points to check
Thank you
[img]
[/img]
 Post subject: Re: WD5000AACS-00ZUB0 not detected
PostPosted: March 30th, 2013, 17:04
Does your drive spin up?
If you install the PM2 (Power Up In Standby) jumper, does the drive appear in BIOS, albeit with a blank model number?
A straight board swap won't work. You need to transfer the "ROM" contents. Unfortunately the ROM is embedded within the Marvell MCU. BTW your MCU is one of those which is commonly affected by a "head mimic" fault.
I can help you with voltage test points if necessary.
PostPosted: March 30th, 2013, 17:44
Dear Spildit and Mr. FZabkar,
thank you for your replay.
Drive doesen't spin up. I connect drive also on equipment and it report that drive is not present.
Thank you
PostPosted: March 31st, 2013, 6:48
Dear Spildit,
thank you for your your suggestions.
I try to isolate conector mentioned, but drive doesen't spin.
I also try to connect only PCB with connected jumpers, to operate in safe mode, and PCB was not detected.
Thank you for all your help
PostPosted: March 31st, 2013, 14:34
Dear Spildit,
thank you for your valuable advices
I will look for donor drive and then continue with work
Have a nice Easter hollidays
PostPosted: March 31st, 2013, 14:53
Any advice.
Thank you
[img]
[/img]
Dear Friend Jerovsek :D
I Have One Adviced For You That Possible To Cross Check Always Conform Both Side First PCB And 2nd Head Stack Preamp So We Can Try First PCB if you Have Any Same PCB Indentical PCB Number That Working Ok Then Put The Pcb And Check Motor Spinup And Head Move Or Not.If Any Clicking Sound Dont Worry Bcoz Of Rom Microcode Not Matching.
Try It And Tell Me What Happend Then I Give Next Advice.
For Your Next Work What To Do.
Yours Friend
Jignesh
PostPosted: March 31st, 2013, 15:40
just for the record...from my researches on a 128k wd rom..the PM2 it's disabled from factory. If I enable it using vsc, on start the drive doesn't ident with ata ident command. it fills only3-4 bytes from the 512 bytes structure. one bit from those bytes signals that the drive its in PUIS mode...and didn't filled the whole struct..so no name no nothing.
in this mode..it doesn't respond even to VSC.
PostPosted: April 1st, 2013, 3:03
Dera Louis,
thank you for your info.
Dear Jignesh.
thank for your suggestions. Currently I have about ten WD5000AA drives, but none of CS. I will wait until I get some, and then try with your suggestions.
Best regards
Jure
PostPosted: April 1st, 2013, 18:03
Here are the voltage test points AFAICT.
I expect that Vcore should be +1.2V or so, and Vneg should be -5V. The latter may or may not be present, depending on whether the motor controller has switched it on or off.
PostPosted: April 2nd, 2013, 5:56
Hello jerovsek
if you need a new PCB and Firmware Transfer here is link to the service and new PCB:
http://www.pcb4you.com/products/wd5000a ... rn-digital
http://www.pcb4you.com/pages/firmware-a ... e-rom-swap
Recuperacion De Datos Dominican Republic
PostPosted: April 2nd, 2013, 6:46
Hi;
You need PCB repair or a new PCB and FW trasfer, maybe HeadStack Problems
