 Post subject: Question by mistake WD
PostPosted: March 31st, 2013, 21:10
Have Zifir. We have a problem. Start with 28 module script.
after the start we 35sek. and blade drive (reset)
then we have the Debug Stop Code .......: 14,108
transcript: RSC_DEBUGSTOP_PERM_ALLOC_TOO_LARGE
Actually the question ... Varya change? or somehow really clear what you do not have enough to run? ...
It seems like it is not enough buffer. but in such a little hard to believe ..
WDmarvel
 Post subject: Re: Question by mistake WD
PostPosted: March 31st, 2013, 21:18
I use many software solutions to repair the drive. PС3000 VDR and more.
I'm trying to start a new Zifire test of 28 modules. but it is dropped. and the error mentioned above.
WDmarvel
PostPosted: March 31st, 2013, 22:19
ideas over?)
WDmarvel
PostPosted: March 31st, 2013, 22:44
All of the above does not work on new Zefir.i all this was done in the first place.
when you try to start the SS have Debug Stop Code .......: 14108
or you will not come across drives new 2012? :D
WDmarvel
PostPosted: April 1st, 2013, 4:56
Spildit,
I use PC 3000 and many other software. everywhere the same debug code
WDmarvel
PostPosted: April 1st, 2013, 6:00
Spildit,
and and head off to the fact that the self does not run a scan? .. if the head was problematic. it has long b solved.
I understand you have not come across WDC WD5000BEVT-24A0RT0 (2012 of release)
WDmarvel
PostPosted: April 1st, 2013, 15:10
There is restriction on this drive for selfscan Sediv managed to break this restriction why dont you talk to him
PostPosted: April 1st, 2013, 16:02
Explains. the reason is not that what that module is not correct or rather step. the question is how to overcome the mistake.
Program versions do not matter here
WDmarvel
PostPosted: April 1st, 2013, 16:43
Use another FW that work. Are you sure you don't have residual FW data on other heads and it is starting correctly ?
PostPosted: April 1st, 2013, 17:22
So we have to have PC3000, WDR, SeDIV and what else ?
PostPosted: April 2nd, 2013, 12:43
rameez, its utility. does not work even with such discs
BlackST, Boil version does not matter. CA itself locked here for the start of the SS
WDmarvel
PostPosted: April 2nd, 2013, 12:48
Spildit, in these drives PST size zero. you can create one with this? ). all you need .. this increase as a PST
WDmarvel
PostPosted: April 2nd, 2013, 12:49
Does anyone got headeache dealing with this english!?
PostPosted: April 2nd, 2013, 12:50
positivebit, in the sense?
WDmarvel
PostPosted: April 2nd, 2013, 12:54
Tink, understanding you.. not in offensive way. :)
PostPosted: April 2nd, 2013, 13:06
positivebit, but you can try to write in Russian?
WDmarvel
PostPosted: April 2nd, 2013, 13:23
only when i have >0.8% alchool in my body ;)
PostPosted: April 2nd, 2013, 15:18
Spildit, actually. I have written the problem, due to which no test runs of the 28 modules
WDmarvel
PostPosted: April 2nd, 2013, 15:49
Spildit, but where does the script from 28 module? ... here the problem with the start) and not with the module. ...
WDmarvel
PostPosted: April 2nd, 2013, 16:35
@Tink,
Sediv designed a new utility to run selfscan on Zephyr . That is why i asked you to contact Sediv.
@Splidit,
WD has put restriction on this family to make it hard to start selfscan so some alterations has to be done in order to run selfscan.
Users browsing this forum: Google [Bot] and 186 guests
