 Post subject: Hello everyone i have WD 500 GB With broken heads
PostPosted: April 2nd, 2013, 8:58
I want to know if I can change them all WD 500 or I have the same exact model
It's because I have a few WD500 but blue not green
Thanks for the help :)
 Post subject: Re: Hello everyone i have WD 500 GB With broken heads
PostPosted: April 2nd, 2013, 9:16
Hi oferav12
you need match correct donnor
you need find it
Is dificult to get correct match. If data is important better contact with a local Datarecovery company.
PostPosted: April 3rd, 2013, 0:39
Thanks for the reply
what is donnor?
Why i think the heads are bad/broken ?
Because of the noise
Do you need the data from the drive or you are just trying to re-use the drive ?
i need the data!
When did it happened and how ?
my hard disk fell
so i need to change the heads
PostPosted: April 3rd, 2013, 5:17
Donor drive= Compatible working (Similar) drive to replace spares from.
If the drive fell, Do not power on the drive.
If you try to fix it yourself you will surely lose your data.
This is not DIY(Do It Yourself)
If data is important , take help from proper Data recovery company.
PostPosted: April 3rd, 2013, 6:31
Maybe let me try to do it myself
What I want is to know what the head is compatible with which the head and I will try.
I have a small lab that closed with plastic face mask and gloves.
And I saw how to do it
But what I need to know what is compatible with what
I was also working hard drive I took the head and put it back after that and the hard disk still worked without a problem
PostPosted: April 3rd, 2013, 7:26
If you are so confident then go for it. Your (?) drive, your choice. Good luck.
PostPosted: April 3rd, 2013, 9:29
If your drive fell -> 75% data lose.
if you do not go to a profesiones -> 99,9% data lose.
Claen room needed
Good look
PostPosted: April 4th, 2013, 1:35
ok
i have
WD5000AAKS S/N wcat00296957
WD5000AAKS S/N wcapw1231350
WK5000AAJB S/N WCAPW3471592
WD5000AAJS S/N WCAS80050381
The heads can be ok for
WD5000AACS S/N WCASU2370917
Tnx for halp :)
PostPosted: April 4th, 2013, 2:52
Did you check HEADMAP in patient AND donors first ?
PostPosted: April 4th, 2013, 6:05
Donors I checked, that's okay
My question is if one matches
Or I have the same model
PostPosted: April 4th, 2013, 6:29
There are so many variables to consider when making physical repairs. Compatibility, stability, surface errors, potential scratches to media, contamination.... How do you plan on confirming donor compatibility, and assuming you get 'lucky' with it, how do you plan on extracting the data from your disk?
PostPosted: April 4th, 2013, 7:13
i have data compass
PostPosted: April 4th, 2013, 7:57
oferav12 wrote:
i have data compass
That's where the problems begin.
You didn't answer to my question : DID YOU CHECK FIRST HEADMAP ON DONOR/S AND PATIENT ?
PostPosted: April 5th, 2013, 1:34
BlackST wrote:
oferav12 wrote:
i have data compass
yes
and patient Not good
Users browsing this forum: No registered users and 55 guests
