 Post subject: Samsung HD103SJ "LED 1A04" Fix
PostPosted: January 12th, 2012, 12:11
Hi All,
I have a Samsung HD103SJ 1TB hd that spins up and then stops. In terminal, LED 1A04 error appears as bellow. It is said the PC3K new version can unlock it and let the hd get ready. But my version is 4.2. Any smart guy can fix it through the terminal commands? Please help. Thanks.
*PA VID=0000 PN=0004 Rev=0002- 785x Found
ChipRev = 63B0
U
S_0
RV En Sensor Circuit
En Shock Sensor Circuit
SO_1
SpinStartUp: mcSpinRPM = 0
RPM at Handoff: 588
Temp : 26 degC
SpinOk
mS1 00000003
SK C:104253 H:0
Loaded FIT ( 0: 0: 1)
CalibTable Loaded. Rev:0x14
Selective MARC NX Loaded
ResoTable Loaded. Rev:0x01
Ovly loaded to 0x0001CD00
Ovly loaded to 0x1005B800
FdtTable Loaded. Rev:0x02
| 19 | RLIST | 2 | 0 |
| 19 | RLIST | 2 | 1 | 256 | 1140 |
| 19 | RLIST | 2 | 2 | 256 | 1140 |
Reading Serial Num Pass
Up MC
TgtCyl: 2032
Hd: 0 Zn: 0 Avg.:- 132
TgtCyl: 266829
Hd: 0 Zn: 1 Avg.: 80
SVCAL(0080,0000)-->PASS
>>InsituStart: t=1695, c=26
GeoId = 49, Idx=49
fodstep: 00000074 dgain: 0000004D
GeoId = 49, Idx=49
fodstep: 0000007B dgain: 00000051
GeoId = 49, Idx=49
fodstep: 00000079 dgain: 00000056
GeoId = 49, Idx=49
fodstep: 00000068 dgain: 00000063
GeoId = 49, Idx=49
fodstep: 00000072 dgain: 0000006
GeoId = 49, Idx=49
fodstep: 00000073 dgain: 00000069
GeoId = 49, Idx=49
fodstep: 00000078 dgain: 00000063
GeoId = 49, Idx=49
fodstep: 00000079 dgain: 0000006A
GeoId = 49, Idx=49
fodstep: 0000007F dgain: 00000064
GeoId = 49, Idx=49
fodstep: 0000005E dgain: 0000005F
GeoId = 49, Idx=49
fodstep: 00000065 dgain: 00000064
GeoId = 49, Idx=49
fodstep: 0000006F dgain: 0000005D
>>Flag=0000028B BadHd=0000 dFod=0023 0028 0023 0024 (t=1805 c=26)
RecordValid Fail : 0007643D 0007E41D
VOP!
PK_4 C:240236 H:0
VOP!
PK_4 C:240236 H:0
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
 Post subject: Re: Samsung HD103SJ "LED 1A04" Fix
PostPosted: April 3rd, 2013, 12:34
i have the same issue with my samsung hard disk
who can help please......... in terminal mode i get below report
S_0SSC EN
SO_1
SSC EN
IS=6
CLA #36/75
Handoff RPM=688
SPOK
SR:50 SS:00000280
mS1 00000003
A1O=1 A1G=431
O=511 S=1
SK C: 5987 H:0
CalibTable Loaded. Rev:0x1B
RRO1xTable Loaded. Rev:0x01
Fw Active 0000
Ovly loaded to 0x00014D00
Ovly loaded to 0x1002E300
| 19 | RLIST | 1 | 0 | 1270 | 1140 |
| 19 | RLIST | 1 | 1 | 1270 | 1140 |
| 15 | VLIST | 1 | 0 | 802 | 1140 |
Up MC
PwrOn RRO1x @ H0
Table) cos = 443904, sin = -530432
Coeff) cos = 28767, sin = -284792
DiskSlip : 74 [SrvTrk]
DiskSlip : 100 [SrvTrk]
TgtCyl: 832
Hd: 0 Zn: 0 Avg.:- 111
TgtCyl: 207552
Hd: 0 Zn: 1 Avg.: 1317
| 167 | DRM | 27 | 0 | 0 | 1140 |
RecordValid Fail : 4107647D 0107E41D
EPOK
SoUL!
PK_4 C: 10148 H:0
Software unloading!
PK_4 C: 10148 H:0
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
PostPosted: April 4th, 2013, 3:01
i have SalvationData HD Doctor, do you think this can help to fix this problem?
PostPosted: April 4th, 2013, 4:12
Spildit wrote:
I think the problem is damaged A-list (check the defect lists).
For bad A-list on this series the disk spins down and remains BSY.
If you have new version of UDMA you can easily solve this. Alternatively you need to get data access via HotSwap. Or, you can outsource it.
PostPosted: April 4th, 2013, 4:37
Submit LE command in the terminal for access reception to the SA and cleaning A-list. Or download HTBI (for example 1AJE37CB.D25, depends from PN) and then there will be an access to SA, cleaning A-list and download Main.
PostPosted: April 4th, 2013, 9:12
Yes, certainly. Probably it is necessary to clear a SMART also.
PostPosted: February 6th, 2014, 2:48
if I clear A-List, will the data on HDD be damaged ? :?:
PostPosted: April 23rd, 2015, 4:19
Hello!
I have a patient drive with LED 1A04 error.
With SRT Pro tool i can access to terminal, but the drive is stays bsy.
The drive is a M7S2 HM161GI, and don't have a donor drive for hot swap.
How can i put the drive to safe DRDY state to clear A-List and smart data?
I have stuck on step "Submit LE command in the terminal for access reception to the SA"
Did i misunderstood something?
Thanks for help.
PostPosted: April 23rd, 2015, 6:35
What happens when you enter in the terminal LE [Enter] ???
PS All you need is any M7S2 drive, and leave only one head (turn off other in the ROM) and you'll have a HDD what you need...
Mikippp
PostPosted: April 24th, 2015, 3:46
Thanks, the problem solved.
The only one step i did not is "hit ENTER" in terminal before "LE" command and after LED 1A04 error. (Thanks Waquas Ali for the good support)
Thanks again!
Cheers!
