 Post subject: Firmware for WD10TMVW-11ZSMS4 01.01A01
PostPosted: April 2nd, 2013, 6:00
Hi guys, need a Firmware for WD10TMVW-11ZSMS4 01.01A01, loader should be OK or a full firmware please.
Recuperacion De Datos Dominican Republic
 Post subject: Re: Firmware for WD10TMVW-11ZSMS4 01.01A01
PostPosted: April 2nd, 2013, 6:31
Is thsi a USB SES Drive?
I have this one
WD10TMVW-11ZSMS1 from a SES drive
valid for you?
PostPosted: April 2nd, 2013, 6:37
USB yes, can I have the pc3000 firmware extraction please
PostPosted: April 2nd, 2013, 9:15
if you have pc3k .udma , i can send you this firmware as PCR database file
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: April 4th, 2013, 7:43
Please send me PCR for pc3000, thanks in advance
PostPosted: April 4th, 2013, 8:31
Loader with non native FW will not work, also after loading LDR in PC3000 HDD will restart and LDR loading will not work. Maybe you can short circuit and read SA via ID. What is the problem with it?
PostPosted: April 4th, 2013, 9:34
1. Drive is coming ready.
2. Decrypting data OK.
http://forensic-datarecovery.co.uk/READ_SECTORS.bmp
3. sectors 0 to 1300000 readable only.
screen when drive is coming ready http://forensic-datarecovery.co.uk/WD10 ... OBLEMS.bmp
on the top of that: service area not readable by ID or copy, heads test not possible to make, head map unable to recognize.
PostPosted: April 4th, 2013, 9:54
I have this one
valid for you?
Sorry for inconvenience i have not FW about this drive
i only have PCB
Sorry
PostPosted: April 4th, 2013, 9:55
can you see any decrypted data? any file?, any folder?
PostPosted: April 4th, 2013, 9:56
LDR will not help you, nor will other SA resources.
My advice, convert to SATA and image encrypted to healthy destination, then decrypt from your destination.
Seems like has some issues and working through USB is not helping , stability through USB will be a problem.
PostPosted: April 5th, 2013, 3:04
I agree with hddguy.
Convert to SATA and then try to image.
Somehow I believe there is a translator issue as well.
PostPosted: April 5th, 2013, 4:00
DRforensic wrote:
screen when drive is coming ready http://forensic-datarecovery.co.uk/WD10TMVW-11ZSMS4_SERVICE_AREA_PROBLEMS.bmp
The WD10TMVW-11ZSMS4 is not Sadle. It's Helios. Its version FW can be 80006, 3008C etc.
PostPosted: April 5th, 2013, 5:37
I agree with hddguy & Northwind . any way here is the resources
http://www.4shared.com/rar/gQ35xD8H/WDC ... A01_W.html
Tawfeek Mokhtar
PostPosted: April 12th, 2013, 2:58
How can you replace PCB card from USB to SATA?
How do you know which card is suitable?
PostPosted: April 12th, 2013, 9:28
Study PCB components for similarities, especially the "main" one for starters.
PostPosted: April 12th, 2013, 10:03
http://cdn.shopify.com/s/files/1/0207/3 ... n.jpg?1921
PostPosted: April 17th, 2013, 6:17
nice
Can you tell me how to do it
That is what the authors why?
PostPosted: September 23rd, 2013, 8:29
I need ROM contents , full FW will be good at all for
WD10TMVW-11ZSMS1
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: October 1st, 2013, 5:07
anyone have the FW resources please for SD? I need it urgent
__________
THANK YOU
SHAHI
Users browsing this forum: No registered users and 195 guests
