 Post subject: ST9500355AS problem
PostPosted: April 5th, 2013, 12:03
I have a Segate Momentus 5400.6 ST9500355AS y external Freagent to Go unit
The disk start to slow copy a failing and window dosen't reconize until conect again.
After that i disamseble and conet via sata and try to probe whith mhdd hdreg hdat2 etc and the behabior for all are the same
The disck in erase or repair operation in any sector that you start the frist sectors are read
and after all sectors are marked as bad.
In mhdd that permit's hot plug (I belive read somewhere) when the drive is not reconize or says not ready
I plug and unplug and the disk let me do eid id and other comands
In the secure erase of mhdd is the same star erase from any sector and fail after a litle time
device not ready again if try any command replug and reconize again.
No click noise of any type.
Sorry if i redundant I'm not english speaker.
 Post subject: Re: ST9500355AS problem
PostPosted: April 8th, 2013, 9:22
What is the cause of this tipical problem?
is the board or the mechanical part?
PostPosted: April 8th, 2013, 10:32
Hi corratge,
if not important waste HDD and buy another one
I you need data contact with local pro The data will be receverable (99% sure). send me a PM in this case
PostPosted: April 8th, 2013, 10:42
Firmware on drive platters?
The firmware of a disk is store in the mechanical part?
hhddrec wrote:
Hi corratge,
I just want repair the disk here hdd are a litle expensive and not are pro service in this area
PostPosted: April 8th, 2013, 10:51
the disk is ST9500325AS sorry
here are to firmwares
http://files.hddguru.com/download/PC-30 ... eagate/F3/
To use PC-3000 to aplly the firmware I ned special hardware or only the software?
PostPosted: April 8th, 2013, 10:58
to use this fw you need PC-3000 (hard and soft) = about 9000$
PostPosted: April 8th, 2013, 11:09
BlackST wrote:
PC3000 UDMA = about 10'000 $ (it is special HARDWARE tool, you read it right, TEN THOUSAND $).
What you get on the link is a saved firmware from a similar disk.
MOREOVER , it won't help you fixing your disk for re-use because each disk is "unique", you simply can't borrow the FW from other disk , it is not a DVD or a cell phone.
OK i'll forget pc-3000,
So there is not profesional atention in my country.
I can try something to fix the disk, anyway noone whill repair it if I don't?
I just one the disk not the data
PostPosted: April 8th, 2013, 11:58
Find a pro near you who can fix the disk for a nominal fee , if possible. Nothing else.
Users browsing this forum: No registered users and 195 guests
