Post new topic Reply to topic  [ 97 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Need firmware for pc3k WDC WD20EARS-00MVWB0 25.12E
PostPosted: April 9th, 2013, 11:26
Hello, my hdd WDC WD20EARS-00MVWB0 Saddle_Back Gen 6 (Royl) has module 006F corrupted (version AOZ30000).
Firmware is 25.12E
Someone may upload 006F module in RPM format or all firmware please?
Thank you.
My firmware database:
 Post subject: Re: Need firmware for pc3k WDC WD20EARS-00MVWB0 25.12E
PostPosted: April 9th, 2013, 11:42
you don`t need it at all
in fact even NEW DRIVES comes with bad 6F
PostPosted: April 9th, 2013, 11:57
What :shock:
New drives with bad 6F ? :?
Do you mean that this module is not important?
So why my drive is very very slow and about impossible to clone?
MHDD sector scan interrupts every few seconds, but no bad sector are found, if i push the right arrow for sector jump it continues to scan but after few seconds stops again, and so on...
PostPosted: April 9th, 2013, 12:16
could be FW
could be heads
could be anything else
BUT NOT 6F
PostPosted: April 9th, 2013, 12:23
If is fw issue i may need to flash it, right?
If so, it's possible to upload it so i can try to flash it?
If is a head issue, may help to depop the damaged one?
PostPosted: April 9th, 2013, 12:39
all depends, on proper diagnose
cannot tell or guess
but should be 1 of those 3 options i suggested
good luck
PostPosted: April 9th, 2013, 12:44
3th option you wrote "could be anything else".
Can you explain it better please?
PostPosted: April 9th, 2013, 12:46
You can try the Solve "slow response" option in the WD utility
But Einstein is correct...
It could be Bad heads, a Faulty board,
Do a head test
But since all the modules are clean i would suspect it is the slow issue. second is a weak head
PostPosted: April 9th, 2013, 12:47
How can i find which head is damaged?
PostPosted: April 9th, 2013, 12:48
Do a head test
No faulty board, i changed it and did rom transfer, same issue...
PostPosted: April 9th, 2013, 12:55
I tried also to reset G-list (which had 41 reallocated sectors) and smart, but nothing has changed.
PostPosted: April 9th, 2013, 13:05
AMNF is always on when i start WDR
Defect P-list
Defects.ini [45.19 KiB]
Downloaded 995 times
IBI Common Log and SS defecs chart:
PostPosted: April 9th, 2013, 13:17
there is a head test in the wd utility. and so is the solve slows solution.
edit - i see your head test now...
try the solve slow solution
PostPosted: April 9th, 2013, 13:20
I should install this?
http://support.wdc.com/product/download ... 71&lang=it
PostPosted: April 9th, 2013, 13:49
no...
in PC-3000 there is a head test, but you already posted a test that shows as good. ( thow it may be wrong)
In the PC-3000, under the WD Utlility Under one of the menu's there is a Solve"SLow responding" SOlution. try that.
that is if you have a pretty recent update of the pc-3000
PostPosted: April 9th, 2013, 13:58
unfortunately i don't have pc3000 :cry:
PostPosted: April 9th, 2013, 14:37
um....
ok...
you subject title of the thread states "Need firmware for pc3k WDC WD20EARS-00MVWB0 25.12E" .
so we would assume you had one.
PostPosted: April 9th, 2013, 14:44
Spildit wrote:
Cleanroom wrote:
um....
ok...
Guess that it was because WDR works with the same file format that PC3K lolololol
Yes, you're right :lol:
PostPosted: April 9th, 2013, 15:10
Spildit wrote:
Cleanroom wrote:
um....
ok...
Good to know. Thanks... never used WDR
Still confusing :)
PostPosted: April 9th, 2013, 19:58
Spildit wrote:
If you can figure out what PC-3000 "fix" is doing, maybe you can do that by hand (editing module, etc ...).
It in fact I was just thinking about this, but I have not idea of what the command Solve SLow responding SOlution does in modules, etc... :?
Users browsing this forum: servohunter and 49 guests
