 Post subject: ST2000DL001 clicking and then spin down
PostPosted: March 27th, 2013, 7:26
Hello, i have a Seagate ST2000DL001 F/W:cc97. When it starts it makes 2 clicks, after 10 more and then spins down.
Atola Insight, shows the drive with wrong results, from Model No.: ST_M13FQBL , to F/W:12211727 to capacity: 4GB
I try to get access with the terminal and i can't.
any suggestions?
thank you in advance
 Post subject: Re: ST2000DL001 clicking and then spin down
PostPosted: March 27th, 2013, 9:30
This is heads 101.
PostPosted: March 27th, 2013, 9:50
Send to Northwind for heads, if not fatal.
PostPosted: April 12th, 2013, 10:57
i just got a donor drive and swap heads. the drive now is clicking twice and then it keeps spinning normally. At DDI after its recognised, when i try to image i get UNC and 0 capacity. Any ideas?
PostPosted: April 12th, 2013, 17:42
Did you examine the original heads under a microscope to check for damage?
Users browsing this forum: No registered users and 216 guests
