 Post subject: wd2500bevt-22zct0 doesn't spin
PostPosted: April 11th, 2013, 15:11
hello all ;
i have a wd2500bevt-22zct0 that doesn't spin up at all .
pcb# 2060-701499-000 rev a
pcb printed #2061-701449-500 AF
pcb has no burn spots and looks totally normal.
i have a donor drive (that has some problems reading SA , drive spins but not detected at all)
tried just to swap the pcbs , but the patient drive doesn't spin either (it produces a tiny sounds of ticking - not related to head assembly as it donut move at all)
did some multimeter measures on the two pcbs and found that :
element working PCB non-working PCB
c25 117 OHM 24 ohm
c26 117 OHM 24 ohm
c24 117 OHM 24 ohm
c4 111 ohm 24 ohm
c1 110 Ohm shorted
c56 75 Ohm 24 Ohm
c57 75 Ohm 24 Ohm
c61 75 Ohm 24 Ohm
d1 76 Ohm 23 Ohm
c70 123 ohm 24ohm
c21 117 ohm 24ohm
any way to repair the broken pcb using the working pcb components ? to avoid the embended flash transfer ?
thank you very much
 Post subject: Re: wd2500bevt-22zct0 doesn't spin
PostPosted: April 11th, 2013, 18:12
What is the resistance between the +1.2V test point and GND? Is it 24 ohm?
What is the resistance between the +3.3V test point and GND?
What voltages do you measure at these points? Don't bother powering up the board if the +3.3V supply is shorted.
PostPosted: April 12th, 2013, 3:44
thank you for your responds ..
YES 24 ohm on the broken pcb and 84ohm on the working one
broken pcb reading 7.55 K OHM and working pcb reading 9.64 K OHM
3V reading 3.25 V , 1V reading 0
PostPosted: April 12th, 2013, 5:33
I suspect that the MCU is responsible for the low resistance reading on the Vcore supply. It also looks like the SMOOTH chip may be bad.
I would check the voltage at the anode of D2. I believe it is probably the negative supply (Vneg) for the preamp.
I would also confirm the voltages at Q1. I believe this is the Vio supply.
There are also two capacitors (C6 and C14) that look interesting, as well as R12 (1 ohm resistor). Could you measure the voltages at these points?
Could you also measure pins 2 - 12 at the preamp connector? I suspect that 10 and 12 may be the VCM pins, but the others are probably the supply voltages.
If you could compare the voltages between your two PCBs, then that would help a lot.
BTW, have you actually observed whether the heads are parked on the ramp, and whether the motor spins by hand?
PostPosted: April 12th, 2013, 9:21
Spildit wrote:
If you have a damaged drive that doesn't spin at all and you place there a pcb from a compatible drive that spins and the damaged drive doesnt spin either, stop waisting you time fixing the pcb because either the pre-amp is shorted or the spindle is stuck.
True that.
Also, another simple "spinning" test is to test the presumably "bad" PCB on your donor drive. Does the donor spin?
PostPosted: April 12th, 2013, 13:59
Presumably bad?
Of course the original PCB is bad. It has no Vcore, assuming the OP's measurements are correct.
PostPosted: April 12th, 2013, 14:13
The suggestion is for any WD drive on a more general basis, not necesarily for this case alone.
Did not read all those measurements.
PostPosted: April 12th, 2013, 14:56
Spildit wrote:
- Place the donnor PCB (the one that spins the drive with SA issues) on the patient drive and INSULATE the contacts to the head stack (J1) with a piece of plastic bag. If the drive spins up that way then Pre-Amp is shorted and prevents the PCB from even spinning it. If the drive still doesn't spin then either spindle is damaged or heads are stuck.
I'm a little confused by the OP's explanation. He said that the heads don't move. AIUI, the WD2500BEVT has a loading ramp. If the OP had looked under the cover, then surely he would have been able to see a stiction fault or spindle seizure. Anyway, if the drive doesn't spin, then why would the OP have bothered to say that the heads don't move?
My feeling is that the PCB may have failed while the drive was spinning. This could then have left the heads over the platters.
PostPosted: April 12th, 2013, 16:21
thank you all again for your help ;
isolating the pre amp contacts will not make the spindle move at all , even on the working drive using the working pcb ...
i DID know that the heads didn't move yet ,without taking off the cover .
having the pre amp shorted is the thing am afraid of ....
donor drive doesn't spin using the paicent PCB.
the measurments are :
Q1 : from left to right
5 **6.75** 4.25 volts
d2 : 0.14 V on the Vneg leg
L1: 0 v (shorted with GND)
c6 : from top to bottom 4.10 ***** 0V
c14:from left to right 4.6V *** 0 v
r12: 0 V from two sides
thank you again for helping ...
PostPosted: April 12th, 2013, 16:26
on the working pcb , readings are
4 **5.10 ***3.25 volts
d2 : 3.05 V on the Vneg leg
L1: 1.4 v
c6 : from top to bottom 8.2 ***** 0V
c14:from left to right 4.75V *** 0 v
PostPosted: April 12th, 2013, 16:41
yes sir ;
i used this trick as u suggested , but even the donor drive wonut spin with it's original working pcb !
PostPosted: April 12th, 2013, 16:54
The readings for Q1 look wrong. The centre pin should be connected to the +5V SATA pins. Either your PSU is BAD or your multimeter is flaky.
L1 cannot be shorted to ground. You previously measured 24 ohms. Instead it appears that the SMOOTH chip is not generating the PWM pulses for the Vcore supply.
Vneg is also generated by the SMOOTH chip. Once again it appears that the PWM pulses aren't there.
Therefore ISTM that your motor controller is dead.
PostPosted: April 12th, 2013, 17:01
L1: 1.4 v
Do you mean -3.05V for Vneg?
If the voltage on C6 is correct, then maybe it's a charge pump capacitor. This would then support my previous diagnosis that the SMOOTH chip is dead, ie a voltage of 4V would imply that the charge pump on your original PCB is not working.
The voltage of 1.4V seems high. AFAICT it should be +1.2V. Is that your multimeter playing up?
PostPosted: April 12th, 2013, 17:25
sorry , my bad
patient pcb Q1 readings: from left to right
3.95 **5.12 ***3.22 volts
PostPosted: April 12th, 2013, 17:28
and once again , am sorry
L1 is not shorted
PostPosted: April 12th, 2013, 17:37
ISTM that you won't be able to retrieve your ROM from the patient PCB. Even if you could replace the SMOOTH chip, it could still be that the MCU is dead.
As for a dead preamp, if you could measure the voltages at the preamp connector, then we could locate its supply pins. Then we could test for shorts right at the HSA.
PostPosted: April 12th, 2013, 17:38
Sounds like you need to get a fully working donor or known good PCB and try again. In DR, time is money and all this useless testing is a serious waste of time in my opinion.
PostPosted: April 12th, 2013, 17:48
yes ... working pcb reading -3.05 v while broken one reading +0.12v V
smooth chip is bad then ... will look for a soldering pro < and see if he can move the smooth chip from one to another ...
thank you , and will keep u updated .
PostPosted: April 12th, 2013, 17:59
I still think the MCU is also dead. A reading of 24 ohms is much lower than your donor PCB. I think it is unlikely that this low reading is due to the SMOOTH chip. The other thing that leads me to suspect the MCU is your resistance reading for C1.
Users browsing this forum: Google [Bot] and 44 guests
