Post new topic Reply to topic  [ 97 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Need firmware for pc3k WDC WD20EARS-00MVWB0 25.12E
PostPosted: April 13th, 2013, 9:37
I post the original rom file, and the one after the "repair"
original and repaired rom.rar [450.41 KiB]
Downloaded 536 times
I think the repaired one which WDR calls NewFlash.bin is damaged.
The original maybe is good (the original rom is 2512.bin)
Someone can tell me if NewFlash.bin is really damaged as i think and why does get damaged when i clic on repair?
WDR should fix it, maybe version 3.0 is not good...
My firmware database:
PostPosted: April 13th, 2013, 9:51
Spildit wrote:
Yes, but it would be a mod that is not in use, and fixing that mod wouldn't change anything, as it's a mod that is not in use.
I understand that MOD 107 is irrelevant, and I understand that the actual problem is a head fault. I'm just indulging the OP and trying to put his own mind at rest.
PostPosted: April 13th, 2013, 10:21
I did a remote diagnosis with A-FF Repair Station, this is the result:
WDR report that the only SA damaged modules are 6F, and 107 and both don't affect the rom repair if i understood right.
Anyway i can't fix them!!
Last edited by michael chiklis on April 13th, 2013, 10:26, edited 1 time in total.
PostPosted: April 13th, 2013, 10:32
ok, i end here.
Give me a information please...
If i use WDR 6.0 and disable head 1 on ram, do you think i will be able to image drive on good heads in normal speed?
If i do selfscan i will lose data?
PostPosted: April 13th, 2013, 13:16
I need a confirm from a PRO if head depop without ram will make loose all data or if is safe.
If depop doesn't destroy data i will try imaging the drive...
PostPosted: April 14th, 2013, 3:18
I can confirm if you disable one head and managed to read the data on the other 5 good heads, the data on the disabled head is still intact.
BUT if the head that is disabled is somewhat damaged in it's "flying capability" then it WILL destroy the surface (data) of that platter.
So it's a high risk for DIY.
http://www.rescue-it.se
PostPosted: April 14th, 2013, 14:49
Before to depop head 1, explain me what should I do to reactivate it later?
To turn on it again should i press reset translator and then recalculate translator with p-list?
PostPosted: April 15th, 2013, 6:40
FWIW, MOD 107 doesn't exist in the following resource dump:
http://www.datadonor.net/HD%20Western%2 ... 0MVWB0.rar
Other MODs such as 102, 104, 105 are "NOT_INIT", so they don't appear to be necessary.
Bytes 0x04 - 0x07 appear to be 01 00 1E 00 in the SA and 04 00 1E 00 in the ROM. Maybe that part of the header needs to be edited, too. ???
I downloaded the resource dump linked by "fzabkar" and i took from it module 32 and i wrote into my drive, then i did fast p-list translator recalculation.
Now the drive is faster in mhdd scan and is detect faster also in bios, but i still have the stop issue after few seconds (anywhere in the drive)
I did a test also with option "logical scan" in WDR.
As you can see i get all "?" after few good sectors.
Example from LBA 0:
I get all "?" from lba 326.992
Another example from LBA 500.000.000:
I get all "?" from lba 500.509.184
If i begin scan since lba 500.509.000, i get all "?" from lba 500.509.432
One more example, from lba 1.000.000.000:
I get all "?" from lba 1.001.439.944
If i begin scan since lba 1.001.430.000, i get all "?" from lba 1.002.494.240
This means that they are not really bad sectors, maybe still translator issue?
I guess the module 32 is clean now, but something more should be fix, any idea?
P.S.
I decided to not do head depop.
PostPosted: April 15th, 2013, 9:32
michael chiklis wrote:
I downloaded the resource dump linked by "fzabkar" and i took from it module 32 and i wrote into my drive ...
I don't know why you did this, but did you match the MOD version?
PostPosted: April 15th, 2013, 9:41
The drive has at least one bad head
PostPosted: April 15th, 2013, 9:56
I notice that in the SMART report the Current Pending Sectors attribute has a worst normalised value of 1. This suggests that at one time there were several thousand pending sectors but these have since been returned to service. Sounds like an intermittent fault to me ...
PostPosted: April 15th, 2013, 10:09
Yes MOD version is the same
My original mod 32:
mod 32 resource dump:
PostPosted: April 15th, 2013, 10:15
Could it be a smart issue?
It's possible to disable smart in WDR 3.0?
This was the original smart status:
Smart status now:
PostPosted: April 15th, 2013, 10:36
SMART isn't the reason for your problems. SMART is merely reporting the problems.
AISI, the Raw Read Error Rate, Seek Error Rate, and Current Pending Sectors were clues that the drive had a head fault. Your defect list pointed to head 4, but subsequent testing hinted at head 1.
Your latest SMART results are typical of a new drive which has not yet recorded sufficient activity in order for the SMART data to be statistically significant. That's why you see a lot of "253" values.
PostPosted: April 15th, 2013, 11:01
If i decide to do head depop, should i do it on head 1 or head 4?
Or both?
PostPosted: April 20th, 2013, 15:42
I tried to copy files and folder in dos with NTFS4DOS utility, but i don't understand why it copies only the first file in the directory.
This utility it ignores all other files in the directory when i give the copy command (it ignores also all sub-directorys).
Maybe the problem is due to the issue on drive... :roll:
Examples of commands which i tried:
1. "copy e:\foto d:foto"
2. "cd e:\foto"
"copy *.* d:\foto"
Both this commands copy only 1 file of the directory (the first one)
P.S.
With NTFS4DOS i'm able to see all files in the directory (with DIR command), but not to copy all of them!!
Do you know some other dos program which are able to copy files and folders for NTFS sourse partition?
PostPosted: April 20th, 2013, 16:10
That's expected, because they are the wrong commands for the result that you are requesting. You need to investigate the DOS xcopy command and its options (e.g. /s /e) in order to copy sub-directories. I haven't used NTFS4DOS - any issues with that are a different problem. You need to try the correct DOS command (i.e. xcopy) first :)
PostPosted: April 20th, 2013, 16:15
I tried xcopy, doesn't detect ntfs partition! :cry:
In NTFS4DOS option /s /e are not able
PostPosted: April 20th, 2013, 16:43
There are other DOS NTFS readers, but I don't know which ones you've already tried... As I explained, when you find one which works for you and which mounts the NTFS partition as a drive letter, you need to understand the limitations of the DOS copy command. Also I didn't see you explain why you are trying to do this from DOS.
PostPosted: April 20th, 2013, 17:17
Because cloning the drive is not an option due to the very low speed (i don't even have those expensive tools for cloning as DDI).
I need to recover only pics folder (which is about 100GB), in dos i can access to the folder directory and i can see all files are inside, but i hadn't luck on copying those until now.
Users browsing this forum: Google [Bot] and 33 guests
