 Post subject: Clicking N Spin Down WD1600BEVT
PostPosted: April 20th, 2013, 15:00
Hi Guys,
Working with a WD1600BEVT-60ZCT1, clicking twice or sometime thrice, then SPIN DOWN.
Suspecting ROM damage initially, later possibility in R/W head.
The PCB doesn't have External ROM, it's embedded in MCU.
PCB No: 2060-701499-005 Rev P1
How do you r/w ROM in this situation?
Just I read ROM in SAFE MODE (PCB Mode) & it's generated 192KB file. Is the ROM operation of SD tool working fine for this PCB by the way?
Also I require ROM/FW resources for this drive.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: Clicking N Spin Down WD1600BEVT
PostPosted: April 20th, 2013, 15:05
Heads bad
PostPosted: April 20th, 2013, 17:56
pcimage wrote:
Heads bad
thanks
by the way, do you have resources for this drive?
also for WD3200BEVS-26VAT0
__________
THANK YOU
SHAHI
PostPosted: April 21st, 2013, 5:00
shahij wrote:
pcimage wrote:
Heads bad
thanks
Probably yes, but firstly it won't do you any good, and secondly even if the heads weren't bad you would almost certainly need the resources from the same version (which you haven't specified)
There are already several resources for this family in hdd files area...
http://files.hddguru.com/download/PC-30 ... ty/Denali/
PostPosted: April 21st, 2013, 10:58
No resources were found till now.
By the way, how to check version/revision of ROM when HDD can't be accessed? Or the ROM is dead/corrupt?
__________
THANK YOU
SHAHI
Users browsing this forum: No registered users and 75 guests
