Post new topic Reply to topic  [ 97 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: Need firmware for pc3k WDC WD20EARS-00MVWB0 25.12E
PostPosted: April 22nd, 2013, 9:24
Sediv free version is not able to load from loader, only generates it (which is the same of module 11).
Does WDR 6.0 able to load the loader?
How?
My firmware database:
PostPosted: April 22nd, 2013, 9:38
Maybe i understood what's wrong on head map...
If i push the button in the red circle, it counts only 1 head:
So i think it can't load SA because 5 heads are off or not counted in head map...
It makes sense for you?
PostPosted: April 22nd, 2013, 10:32
Now if i push the button in red circle i get always 6, :lol:
PostPosted: April 22nd, 2013, 14:01
Spildit wrote:
You have a messed up head map.
Tick the 4 first ones and untick the others. Then save.
No!
0,1,2,5,6,7 is valid head map for SadleG6 drives
PostPosted: April 22nd, 2013, 15:26
Logical vs Physical
Not always the same
Typical 2Tb SadleG6 has physical 0,1,2,3,4,5 (i.e. all populated) but logical (ROM head map) 0,1,2,5,6,7
As a typical 500Gb Tornado have 2,3,4,5,6,7 in ROM, but 0,1 are not physically missing.
I have no idea how WDR (or whatever software he used) decides which is which for "de-popping".
PostPosted: April 22nd, 2013, 20:58
In the pic you can see that i have depopped head 4 on "virtual head"
If rom head map is 0,1,2,5,6,7, what physical head has been turned off?
(maybe head 5) :?:
PostPosted: April 23rd, 2013, 5:50
It's a "Road Map error", i don't know how to fix it.
PostPosted: April 23rd, 2013, 16:53
Spildit wrote:
Did you really restore ROM using the external programmer ?
Yes Spildit, i restored with my eeprom programmer, nothing change.
PostPosted: April 23rd, 2013, 17:28
What should i do now?
PostPosted: April 23rd, 2013, 17:37
No it doesn't read, i get ~id0001.bad (0 byte) if i push "read" :shock:
P.S.
i copied the 01 module from my backup folder to WDR working folder, then i pushed "write" into w/o road map window.
Still i can't see modules.
P.S2
If i push once again "read" after i write 01 backup, i still get ~id0001.bad
Last edited by michael chiklis on April 23rd, 2013, 17:47, edited 1 time in total.
PostPosted: April 23rd, 2013, 17:51
i already "played" today afternoon with "Auto Good Map" and "Heads Map on", but i still can't see modules.
The only way i can see modules is when i do Road Map - Via enumeration, but i'm not able to read or write them
What can you tell me about "init" button on w/o roa Map?
Last edited by michael chiklis on April 23rd, 2013, 17:54, edited 1 time in total.
PostPosted: April 23rd, 2013, 17:56
Virtual head it's already set to 6
PostPosted: April 23rd, 2013, 18:01
If one haead is off now (suppose one which reads the SA), why can't i read SA from the other head?
SA is on 2 heads (0+1), right?
PostPosted: April 23rd, 2013, 18:11
ok thanks, tomorrow i will ship the drive in rma
PostPosted: April 23rd, 2013, 20:59
Head depop writes also in some SA modules (WDR 3.0 works this way).
If you read my previous posts, when i did the head 1 depop, i couldn't turn on head 1 with only ROM restore (the drive was still identified as 1500 GB but modules were accessible), after i restored SA modules from backup the drive was again detect as 2 TB.
viewtopic.php?t=25749&f=1&start=120#p175449
Maybe head mapping change only ROM information, but head depop does also SA changes.
If i had made ​​the head map instead of the head Depop, maybe all of this would not have happened, but now ...
PostPosted: April 24th, 2013, 6:20
To 'depop' a head will change sizes of zones, which will make data recovery impossible. Change head map in RAM retains zone sizes, but if head other than SA head is set it wont read anyway, also for Sadle head map edit process in commercial tool is not same as older series.
PostPosted: April 24th, 2013, 7:06
Spildit wrote:
Thanks for sharing.
I guess that it's RMA time now !
I packed up the drive this morning, now i'm waiting the arrival of the courier.
Thank you every one who helped me and who gave explanations.
Users browsing this forum: jimmydata, Majestic-12 [Bot] and 51 guests
