 Post subject: Spindle motor Doesn't spin up
PostPosted: April 25th, 2013, 23:51
Hi Everyone,
2TB Seagate hdd Spindle motor doesn't spin up.
what's problem in PCB?
Regards,
 Post subject: Re: Spindle motor Doesn't spin up
PostPosted: April 25th, 2013, 23:53
Did you check if the bearing is free to spin? It may not be a PCB problem.
If it is a PCB problem, it could be several things . . . Smooth chip, corrupted ROM, TVS, etc.
http://www.datasaversllc.com
PostPosted: April 26th, 2013, 0:16
Ideally get hold of a Donor PVB and swap the ROM Chip
PostPosted: April 26th, 2013, 2:34
Firstly, as jono says, make sure the problem IS the PCB.
Does the drive make ANY noises at all when power applied?
(E.g. Buzzing noises)
PostPosted: April 26th, 2013, 3:30
Thanks for all replays
Donor PCB with checked, same problem in.
almost problem in Spindle Motor also...
PostPosted: April 26th, 2013, 10:09
Spindle Motor problems or head stack problems
you need check those
Users browsing this forum: No registered users and 161 guests
