 Post subject: How Can i write Rom In Wd marvell ??
PostPosted: April 25th, 2013, 19:27
i am trying to write the rom in wd drive i have all time failure rom is write successfull but after write the rom i am switched off the drive and try switched on but drive is not spin i have change rom chip drive is spin up try to second time face same problem how can i match the rom in drive plz any suggestion
 Post subject: Re: How Can i write Rom In Wd marvell ??
PostPosted: April 26th, 2013, 2:35
What tool you using to write rom?
What model WD?
PostPosted: April 26th, 2013, 8:02
i am using pc 3000
and i am write a rom from wd marvell sabre 53 series is'nt working how can i solve this??
PostPosted: April 26th, 2013, 9:57
The WD is at safe mode, or no?
PostPosted: April 26th, 2013, 9:59
are you sure you are writing the write rom over? typically when i see rom copies that cause the drive not to spin (brick the PCB) , it is that the rom you are transferring is damaged. or completely not compatible.
PostPosted: April 26th, 2013, 10:49
how can i check rom have compatible or not compatible and
how can i check rom is damaged or not ?
PostPosted: April 26th, 2013, 15:22
but spildit how can judge the rom is damaged or not how to chek it plz tell me full instruction sir
PostPosted: May 5th, 2013, 4:24
as other guys sais here the best is to upload ROM to see it.
Users browsing this forum: No registered users and 253 guests
