 Post subject: SeagateT 7200.10 ST350083AS Bricked Drive
PostPosted: May 6th, 2013, 7:59
I have here a ST 7200.10 Bricked Drive.
I think ROM BRIKED.
Tha HDD do not start, and see Picture to PC3k status.
Any way to upload FW to ROM?
 Post subject: Re: SeagateT 7200.10 ST350083AS Bricked Drive
PostPosted: May 6th, 2013, 8:00
Pic here
PostPosted: May 6th, 2013, 9:00
Spildit wrote:
Doesn't it spin at all ?
Try to insulate the contacts to the head stack and see if it spins.
Anything on terminal ?
This will exclude a shorted pre-amp.
Does the pcb have a ROM chip ? Do you have external eeprom programmer ?
thanks Spildit for your quick help
Nothink
I try it, but not spins
no, Nothink on terminal
Yes have it a ROM, but i have not external programer
PostPosted: May 6th, 2013, 9:39
Sure PCB is good?
PostPosted: May 6th, 2013, 13:57
I think ROM BRIKED.
Dear Friend HHDDREC Dont Worry About This Drive Just Find The Matching Donor And Direct PCB Swap Is Possible In 7200.10 If Problem In ROM Or PCB Your Case Is Solved This Way.If Any Of Same PCB You Have Then Try First The Eprom Swap And Check It If Drive Not Responding In Terminal That Mean Your Rom Is Gone Find The Matching Donor And Swap PCB Directly.
Yours Friend
Jignesh Pankhania
PostPosted: May 6th, 2013, 14:00
Thasnk jignesh
Yes i know, but i prefer test ROM and if necesary reprogram ROM.
PostPosted: May 6th, 2013, 14:03
hhddrec wrote:
Thasnk jignesh
Brother Some Time Reprogram Rom Not Work If Rom Allready Currepted.
2nd Thing If You Have Much Work Then Dont West Time Be A Proffesional.
Never West Your Time In Knoledge Allready You Have.
I Only Focus Solve More Case Per Day If We Know Easy And Time Saving Solution Then Why We Make Our Way Long.
When You Have Much Work This Thing Is Helpfull Very Much
PostPosted: May 6th, 2013, 14:15
jignesh wrote:
hhddrec wrote:
Thasnk jignesh
Ohh jignesh.
Great for pro people here, do not waste time
good known.
Thanks jignesh i'll do it.
PostPosted: May 6th, 2013, 14:35
hhddrec wrote:
jignesh wrote:
hhddrec wrote:
Thasnk jignesh
Ohh jignesh.
good known.
Thank You Very Much And If Any Problem And Need Help Just Contact On My MSN @ jignesh.pankhania@hotmail.com When I Am On Work My MSN Messenger Always On.I Reply When I Am Available.
Yours Friend
Jignesh Pankhania
PostPosted: May 7th, 2013, 14:33
Thanks to Spildit and to jignesh.
Users browsing this forum: Google [Bot] and 258 guests
