 Post subject: How many flash chips are in a 32GByte SD card?
PostPosted: April 30th, 2013, 13:51
My understanding is that the largest flash chips available are 256Mbit (32MByte). To build a 32GByte sd card would require 1000 32MByte flash chips. I must be missing somwthing.....no way there are 1000 flash chips in that little package ;-)
Can someone set me straight?
thanks!
 Post subject: Re: How many flash chips are in a 32GByte SD card?
PostPosted: April 30th, 2013, 14:01
1 or 2, usually.
PostPosted: April 30th, 2013, 15:36
Micron has 128Gbit and 256Gbit NAND Flash chips:
http://cse325.floorsoup.com/refdocs/hw_ ... _flash.pdf
PostPosted: April 30th, 2013, 15:43
Thanks! That explains it.
PostPosted: May 1st, 2013, 8:57
most likely it is a Monolith chip
PostPosted: May 1st, 2013, 9:02
Party pooper!
PostPosted: May 1st, 2013, 12:46
From the spec sheet ..
Package
– 52-pad LGA
– 48-pin TSOP
– 100-ball BGA
– 132-ball BGA
PostPosted: May 6th, 2013, 12:31
Package
– 52-pad LGA
– 48-pin TSOP
– 100-ball BGA
– 132-ball BGA
Had to go and get technical to prove me wrong :)
PostPosted: May 6th, 2013, 14:38
Cleanroom wrote:
Package
– 52-pad LGA
– 48-pin TSOP
– 100-ball BGA
– 132-ball BGA
Ha ha :-)
Users browsing this forum: Ahmed Saeed and 125 guests
