 Post subject: Deepspar Add-on
PostPosted: May 11th, 2013, 15:15
Not a PC3000 question but this is the closest
Would like to get feedback if you used USB add-on.
Success rate with out using PC-3000
 Post subject: Re: Deepspar Add-on
PostPosted: May 13th, 2013, 18:37
I am not impressed with it!
PostPosted: May 14th, 2013, 9:15
I use it every day.
PostPosted: May 15th, 2013, 15:10
We use it occasionally, but wouldn't find it too helpful if we didn't also have a pc3k to fix firmware problems. Swapping to SATA always seems more reliable and faster when the drive has lots of bad sectors. But, if the drive is in pretty good shape, it's more convenient to clone "unencrypted" and skip the later step of decrypting the clone.
PostPosted: May 17th, 2013, 8:57
I've found it works well with Toshiba and Samsung native USB drives with degraded media, but WDs are a different story.
Tool does work well for the correct applications.
Data Recovery Cape Town
PostPosted: June 5th, 2013, 22:36
how come you dont like it ????
that add on somewhere between $2,400
PostPosted: June 6th, 2013, 10:50
Pretty much what bcometa said,
It's really only useful if the drive has minor issues, and most drives we get in for recovery are way past minor issues. Most have been dropped, have platter damage, etc... After replacing heads reading via USB command set is just not something I think is a good idea (at least in the current implementations). And if you switch the USB add on to use ATA command set, now your dealing with the encrypted drive, in which case it's a lot better to just go sata and maintain as much control as possible over the drive.
