 Post subject: Hard drives in 0G
PostPosted: May 12th, 2013, 17:22
Okay, it not like I will take one into Outer Space or whatever, but what would happen to a hard drive if it was working in a space craft with no gravity. I guess it will work normally, what do you think?
My next question is, what would happen if the hard drive was working with the cover off and in outer space itself. Would it work. I guess it will spin and do the normal things, but without air, the heads can't float on the disk surface. Am I wrong? Let me know :)
Shane
 Post subject: Re: Hard drives in 0G
PostPosted: May 13th, 2013, 2:43
So long as it has air with an equivilant pressure pressure below 20,000' ( I think ), it should be fine with current designs. The effects of gravity are likely negated by the various tweaks that the heads can have applied on the fly ( point in fact, you can operate the drive in any orienatation these days without issues ).
You have a backup...right? | Tech Repairs on YouTube
PostPosted: May 25th, 2013, 20:34
it would work no problem as the air pressure would be the same
as if you where on earth
