 Post subject: CLICKING NOISE
PostPosted: May 14th, 2013, 5:19
Hi Friends,
I need firmware for
WD400BB-00FJAO
DCM: HSCHCTJAH
PCB: 2060-701335-003
how can solve this problem ?
 Post subject: Re: CLICKING NOISE
PostPosted: May 14th, 2013, 5:57
If it is clicking, then 99% a physical issue (e.g. heads)
PostPosted: May 14th, 2013, 7:03
Firmware is not needed to resolve case.
Ensure PCB is not the problem first.
Then move onto other tests.
PostPosted: May 14th, 2013, 15:31
i think this is a rom issue r u swap the pcb ??
PostPosted: May 15th, 2013, 9:56
dear
the problem is that i have no same pcb for this hard disk..
PostPosted: May 15th, 2013, 10:08
-FJA- can not be ( UNICORN )
PostPosted: May 15th, 2013, 10:16
what do you mean (-FJA- can not be ( UNICORN )?
PostPosted: May 15th, 2013, 10:22
WD400BB-00FJA0 must be (MAMMOTH) NOT (UNICORN).
PostPosted: May 15th, 2013, 16:31
i agree with unknown 00fjao is mamoth family not unicorn
PostPosted: May 15th, 2013, 18:49
A Google search turns up 2060-001130 as the PCB number for the WD400BB-00FJA0.
It's easy enough to compare the date code on the label against the date codes on the PCB and on the chips.
PostPosted: May 15th, 2013, 20:50
Why do you have a SATA PCB on a PATA drive?
PostPosted: May 16th, 2013, 0:42
Abdul Rauf wrote:
dear
Have you tried what I suggested in the PM?
PostPosted: May 18th, 2013, 11:02
give 300 temperature heat to its original PCB, there are chances it ll work, otherwise you can write back i ll provide you the firmware
Azzan Shahid
No one is master in this world but only His Almighty
www.datarecoverytanzania.co.tz
Users browsing this forum: No registered users and 192 guests
