Post new topic Reply to topic  [ 155 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
 Post subject: Re: WD5000BMVV connector
PostPosted: April 1st, 2013, 3:09
I do not hear it spin up. Sound was not that good. Does it indeed spin up? Do you have a good working drive to compare?
PostPosted: April 1st, 2013, 11:33
It feels like spinning up... but after the sound stops the gforce stops and it spins down. Spare? Not the same model...
PostPosted: April 4th, 2013, 11:58
If your data is important contact with a Pro, because your hard disk drive neesd clean room.
platter and/or spindle are jammed
contact local pro
PostPosted: May 15th, 2013, 21:01
Hi, i have the same HDD, and i managed to rescue data from it. I removed 4 capacitors to disable controler, and connect it to external SATA. Then Win recognized HDD and i was able to extract data with tool "Get Data Back" it was slow but i have patience.
I put vent to cool it, because HDD was getting hot.
PostPosted: May 16th, 2013, 2:33
No encryption?
PostPosted: May 16th, 2013, 16:37
pcimage wrote:
No encryption?
Elements?
PostPosted: May 16th, 2013, 16:56
don't all integrated USB port on WD laptop drives have encryption. I have yet to see one that did not. Not sure how he got data from the bypass
PostPosted: May 16th, 2013, 17:36
AIUI, Elements drives are not encrypted:
viewtopic.php?f=1&t=25627
PostPosted: May 16th, 2013, 20:10
Whats the full model number?
PostPosted: May 17th, 2013, 9:10
I know some of the desktop elements did not have encryption, but the laptop ones always seemed to have it. Maybe i just never saw one. but every integrated USB PCB from WD has always been encrypted for me, and I have seen hundreds of them over the last year.
PostPosted: May 17th, 2013, 9:21
They are uncommon but do exist. I had one this week (WD2500BMVU-11A04S0).
PostPosted: May 17th, 2013, 10:15
good to know, thanks
PostPosted: May 17th, 2013, 13:08
I've had a couple of 1tb elements drives that were not encrypted too.
PostPosted: May 17th, 2013, 15:02
I thought that one of the characteristic differences between Elements and Essentials models is that the latter are encrypted whereas the former are not.
PostPosted: December 12th, 2013, 12:45
Hope this tread is alive.
I have an WD Elements 500gb USB WD5000BMVV and hope you guys can help me.
The disk is recognized in Windows but says it needs initialization. So iv tried to rewrite the MBR but every software iv tried says cant read or write protected. Is this a connector problem perhaps? Do i need to re-solder it or?
PostPosted: December 12th, 2013, 13:06
It is not uncommon when adding a new drive; whether it be formatted or not; to need to be initialized by windows.
Generally I just press Yes and from that point on Windows can work with it from within Disk Management.
PostPosted: December 12th, 2013, 13:07
PostPosted: December 12th, 2013, 13:15
Yes, i know,but this one gets Write Protected Error
And the light is always on and disk is spinning
PostPosted: December 12th, 2013, 13:30
Have you tried the "attrib disk clear readonly" for that volume from within diskpart?
PostPosted: December 12th, 2013, 14:01
Another solution to try is to disable write caching on the usb hdd in device manager.
You can choose in the disk properties for optimize for quick removal or optimize for performance. CHOOSE optimize for quick removal.
Users browsing this forum: Google [Bot] and 170 guests
