Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: Seagate ST3500312CS - G1 equiv
PostPosted: May 17th, 2013, 10:51
bomex wrote:
I found this answer on the internet, someone can take the test and see if it works? And also post photos?
i took all the posts i read in this thread and used all the data to formulate the solution the main tools you will need is a working directv dvr in my case a HR22-100 it has a 500gb seagate hdd model ST3500312CS and HDAT2 bootable cd these drives are DCO frozen you have to boot the drive up in the dvr so it wakes and unlocks them then do a hotswap meaning leaving power to the drive after it activates then connect the sata connector to a computer and boot the computer with hdat2 cd. the proceadure: 1: select option 1 from the menu 2: once it goes to a command prompt type HDAT2 3: once HDAT2 has started select the drive model that you are working on and press enter 4: the first thing under the menu you want to do is select "Device Configuration Overlay (DCO) menu" under there you need to select "Restore" at the bottom of the screen it will prompt you for a Yes/No just hit Y let it do its thing and it should comeback with some code and some words in green. 5: now we need to hit escape till were back to the menu and we need to select "Comands Menu" and hit enter under comands menu select "commands/feature sets" and hit enter you will see a lot of things in gray and yellow we are only going to touch one thing here and thats the "Power-Up In Standby (PUIS)" we want to disable this by highlighting it and pushing the right arrow then hit the s key it will prompt you for a Y or N ht Y for yes it will say working and then should finish wothout error and turn to dissabled. now to test to make sure it worked.
The above solution wont work if the drive has security set to maximum. (dont know if it works at all)
This is how i unlocked my ST3500312CS using HDAT2:
Wake up the HDD in DVR so that its "SECURITY:ENABLED" (instead of "ENABLED+LOCKED" when booting from PC bios)
Go to security options -> Set Password
Change Master Password to Seagate+25spaces.
Go to security options -> Erase Unit
Using this new password erase the drive in enhanced mode.
After ~1h30Min drive is unlocked.
^This is how it worked for me. I'm not sure if it has to be "enhanced mode"
PostPosted: July 24th, 2013, 17:23
The user states that his drive is in DCO freeze lock,therefore the solution will work as his drive is not locked via the HDD security feature.
Mark
PostPosted: December 17th, 2014, 6:38
Dear ALL:
i have seagate pipeline 2TB HDD.. Please tell me solution to disable PUIS. when i connect drive through SATA cable my PC wont boot up & its stuck on start-up with HDD light static. my drive wont spin at all however it shows capacity in drive management when i connected it through USB power. i heard HDAT2 will not work on USB connection but it show my drive also in HDD selection menu.
PLEASE HELPPPP !!! :(
Users browsing this forum: Google [Bot] and 241 guests
