 Post subject: Identifing ROM on Toshiba MK4026GAX
PostPosted: February 10th, 2012, 7:29
Hi guys,
Had a drive which didn't spin. Swapped the PCB with an idenical donor. Drive now spins but clicks.
Is there adaptive ROM on these hard drives? (IC12?)
Toshiba
MK4026GAX
 Post subject: Re: Identifing ROM on Toshiba MK4026GAX
PostPosted: February 10th, 2012, 7:33
DanR wrote:
IC12
:good:
PostPosted: February 10th, 2012, 7:40
hddguy wrote:
DanR wrote:
IC12
:good:
Thanks for confirming.
Better be safe than sorry!
PostPosted: February 10th, 2012, 17:15
FYI, there is a fuse (F1) near the end of the IDE connector. D1 appears to be a TVS diode.
PostPosted: February 10th, 2012, 17:28
F1 is very common to blow
PostPosted: February 13th, 2012, 7:44
Thanks guys, Did the ROM transfer and the drive is now imaging.
PostPosted: February 13th, 2012, 12:04
Well,
Great Job
PostPosted: May 18th, 2013, 6:11
I have a similar board, can you tell me what fuse and tvs you recommend as a substitute? Or is it easier to go for a board? Thanks.
Those who know don’t talk. Those who talk don’t know.
PostPosted: May 18th, 2013, 16:13
If there is no other damage, then you can remove the diode and bridge the fuse with a blob of solder.
Otherwise ...
Littelfuse Surface Mount Fuses, N = 2A, S = 4A:
http://www.farnell.com/datasheets/48294.pdf
SD05-7, Diodes Inc, marking ZA, 5V, 350W, UNI-DIRECTIONAL SURFACE MOUNT TVS:
http://www.diodes.com/datasheets/ds31594.pdf
PostPosted: May 22nd, 2013, 4:50
Thank you for your help.
Users browsing this forum: No registered users and 198 guests
cron
