 Post subject: seagate 7200.12
PostPosted: May 28th, 2013, 23:42
Hi
Rst 0x08M
No HOST FIS-ReadyStatusFlags 2002B001
ASCII Diag mode
F3 T>/2
F3 2>Z
HighPowerMode
Spin Down Complete
Elapsed Time 0.102 msecs
F3 2>U
HighPowerMode
ExecuteSpinRequest
Spin Up Complete
Elapsed Time 3.763 secs
F3 2>/t
F3 T>m0,2,2,,,,,22
RW subfile error 201F
SIM Error 201F
DiagError 0000500E Process Defect List Error
R/W Sense 00000002, R/W Error 841C0087, List Offset 00000000, List Index 0025633B, File Error 000000D0
F3 T>
please, how to fix
thanks
 Post subject: Re: seagate 7200.12
PostPosted: May 29th, 2013, 8:39
F3 T>/2
F3 2>Z
HighPowerMode
Spin Down Complete
F3 2>U
HighPowerMode
ExecuteSpinRequest
Spin Up Complete
Why do you do this?
F3 T>m0,2,2,,,,,22
And why do you instantly run this command without checking the presence of of complications like non resident list?
If this is a clients disk, I suggest you send to a professional.
PostPosted: May 29th, 2013, 9:50
Another 7200.11 tutorial followed blindly for a 7200.12 ... :(
PostPosted: May 29th, 2013, 11:10
hddguy wrote:
F3 T>/2
F3 2>Z
HighPowerMode
Spin Down Complete
F3 2>U
HighPowerMode
ExecuteSpinRequest
Spin Up Complete
Why do you do this?
F3 T>m0,2,2,,,,,22
I am using seagate HD doctor.
I want to repair, do not need data.
I can not check any public list.
I can not load from HDD
PostPosted: May 29th, 2013, 11:15
What is the command used to 7200.12
any signal you can give. I think it will get the error.
PostPosted: May 29th, 2013, 11:57
y0k090 wrote:
do not need data.
Why would you want to repair? chances are its under warranty, RMA it.
PostPosted: May 29th, 2013, 21:22
hddguy wrote:
y0k090 wrote:
do not need data.
I need to fix it.
I have followed the statements Salvationdata forum, but no success.
PostPosted: May 30th, 2013, 4:52
SIM Error 201F
It is "something more" than usual problems , "internet fix" doesn't work in this state and also, in my opinion, is dangerous for data. Does SA read ?
PostPosted: May 30th, 2013, 5:06
The translator command was run instantly after spinup, this will never work and always produce error.
PostPosted: May 30th, 2013, 5:36
This command is always used for the following cases:
Rst 0x08M
why it can not be used in this case.
70% success when using this command.
the problem is there any other way, I was trying to test the command.
results are not as expected.
PostPosted: May 30th, 2013, 5:38
if the bad sectors in SA, how to fix, or no solution.
Salvation is often said by the SA, but they can not provide a solution.
cron
