 Post subject: WD2500AAJS-75M0A0 - Mods 11 and 12 Required
PostPosted: May 30th, 2013, 6:24
Hi guys,
Looking for anyone that has modules 11 and 12 for the above drive Firmware REV 000500FF
Thanks in advance...
Steve..
http://www.eadr.co.uk
 Post subject: Re: WD2500AAJS-75M0A0 - Mods 11 and 12 Required
PostPosted: May 30th, 2013, 7:14
Hi Steve
I have 500FA if you wish to try.
PostPosted: May 30th, 2013, 7:25
Hi Dimitris,
Yes please.....
Many thanks...
Steve
PostPosted: May 30th, 2013, 8:33
FF seems rare as that is the one I don't have.
See some other ones in the fw section under UDMA support.
PostPosted: May 30th, 2013, 10:31
BTW this model is : WDC WD3200AAKS-75L9A0 02.03E02 WD-WCAV2X005296
000500FF.rar [152.88 KiB]
Downloaded 446 times
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: May 31st, 2013, 3:25
Here it is, good luck mate:
Model: WD2500AAJS-75M0A0
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 2
>Cyl Count............................... : 170
>Zone allocation table................... : Ok
>SA SPT.................................. : 1311
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 192 Kb
>ROM version............................. : 05.FAE
>ROM generation.......................... : 05.FAE
>Link table version...................... : 04.0E.
>Consolidated ROM version................ : 000500FA
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Modules directory address............... : FIXED
>SA regions address...................... : by default
>Heads configuration..................... : by map
>Heads number in use..................... : 2
>Switched off heads...................... : No
>Heads map............................... : 0,1
>ROM Firmware version.................... : 000500FA
>Service area:
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
Copy 0.rar [158.33 KiB]
Downloaded 453 times
PostPosted: May 31st, 2013, 4:51
Thanks for this Dimitris, ........
I have also had a workaround PM'd by hddguy........... and will be working through this case at some point today...
P.S... Liking the hat, dreads and the extremely large 'Menthol' Cigarette.... :lol:
Users browsing this forum: No registered users and 85 guests
