 Post subject: What is the SATA PCB for 701650?
PostPosted: June 5th, 2013, 12:30
Full code of USB: 2060-701650-000 REV P1
Searching on my own in the meantime... maybe can save time this way.
 Post subject: Re: What is the SATA PCB for 701650?
PostPosted: June 5th, 2013, 12:41
I know SATA PCB for 701675 USB, it's 1672.
But 701650 unfortunately, without external ROM.
PostPosted: June 5th, 2013, 12:48
Indeed no ext ROM. But can potentially find other ways to read and write ROM from USB to SATA, right?
PostPosted: June 5th, 2013, 13:28
Seems like F9 drives, code 701499
PostPosted: May 8th, 2015, 7:44
Hi Guys ,
What did you do in this case .Whats the SATA PCB You Used .As I Have a Tool That Cannot Connect To USb and Work With Firmware The Only Possibility I See to Read Rom Is Either Tap SATA Lines Or Transfer The Complete MCU .Need Your Suggestion .This Drive is a Self HDD Needs No DATA Recovery And is also Smartware Protected .No U12 ROM in This PCB :lol:
PostPosted: May 8th, 2015, 8:16
701499
you can solder a sata connector to it
PostPosted: May 8th, 2015, 8:32
jermy wrote:
701499
Well,
Sometimes i Can Solder a MCU Faster then Tapping Sata Lines .Would Love To Give a Demo Video One Day Very Soon .Might Be Some of You Can Learn It the Easy Way
PostPosted: May 8th, 2015, 8:34
Here's all of them that are known at this time: https://www.data-medics.com/forum/viewt ... ?f=25&t=13
You should bookmark the site. :D
PostPosted: May 8th, 2015, 8:36
Well,
I Dwell In That Thread Too Lol Right Buddy
PostPosted: May 8th, 2015, 8:41
If you have PC-3000 you can read the ROM code via terminal, or even via boot ROM if that doesn't work. I've yet to ever have to transfer an MCU for one of these.
PostPosted: May 8th, 2015, 9:34
Well,
Might Be i Could Connect COM RS232 To Those Male Header 12 pin i think and get ROM Out .Just Need The Data Of That 12 Pin Header "though Its Open In the Domain Now " .Might Be Someone Can Share And My Time is Saved :mrgreen:
PS : MRT Works In Terminal Mode For Your Info :D
Users browsing this forum: No registered users and 31 guests
