 Post subject: Move the Main Controller IC (the biggest chip on the board)
PostPosted: June 8th, 2013, 23:24
I keep seeing this in alot of post "Move the Main Controller IC (the biggest chip on the board)", but does that mean a DIY cant do it?
The number on the green part of the Original board is 2060-701537-004 REV A. On the White label it is 2061-701537-R00 AD. It's for a WD7500AACS-006B0 External drive.
I need this kind of swap to make my HD work again to get the data off but I havent seen anything on how to remove the chip.
My issues started back in Feb when my drive wasn't found in windows so I opened the enclosure and separated the drive from the case and plugged it into the Motherboard sata connection. still no sign of it in windows and the drive wasn't spinning.
So I contacted Datapro and they had me to send them the pcb for repair and I think they finally finished off the pcb. After 3 months after being sent out the pcb is burnt up and still doesn't power the HD (wont spin)
In the mean time I got on the ebay and bought another drive, thinking I could just swap the pcb's and get my old HD to work. The numbers on that board are (2060-701537-004 REV A) (White label 2061 701537-R00 AD XC 6Q05 8EXN M 0002060 9062) and this drive is a working drive and windows finds it.
So I swapped the pcb on to my old drive that I want the data off of and the drive will spin,but it isn't found in windows.
So then I found out that the bios might need swapped from board to board to make it work, but I ran up against the Main controller swap problem and I don't see a way for me to get it off to try it.
I've tried searching google and this forum and also youtube to see if I could find a demonstration video on how this is done, but I havent found anything yet.
So now I'm asking to see if anyone could offer any help in this?
 Post subject: Re: Move the Main Controller IC (the biggest chip on the boa
PostPosted: June 10th, 2013, 7:51
Just a question - all the charring of the PCB around the controller chip, is that how it came back from the repair service? If so that's just an attrocious job, it's like someone with no clue hit the board with nothing more than a household paint-stripper/heatgun for far too long without any protection to the parts around the chip. Sure looks like the board is completely dead now!
Can you provide a larger version of the burned photo?
You have a backup...right? | Tech Repairs on YouTube
PostPosted: June 10th, 2013, 7:55
This model has no external ROM meaning the native ROM can be restored from the SA without the need for a repair of the native PCB.
Do yourself a favour and send the entire HDD, not just PCB, to a reputable firm who can handle it safely for you. As far as DIY goes, assuming there is no other problems, the process of restore ROM from SA is relatively straightforward, but requires specialist equipment and knowledge of the process. Also, there is always the possibility of other complications which can be addressed directly by a professional.
PostPosted: June 10th, 2013, 15:24
Who is data pro? A recovery specialist? A cable dealer? A consultant firm?
PostPosted: June 10th, 2013, 17:09
HDDZone are hitting all the storage forums. That's where the "Move the Main Controller IC" advice is coming from.
http://www.hddzone.com/faqs.html
1. Can you advise the firmware code of your board?
We can't confirm the firmware code with you. In most cases, you should move your original PCB's BIOS/Main Controller IC to the replacement board.
10. What does this mean "This PCB's BIOS is integrated on the Main Controller IC. You should exchange the Main Controller IC to let the HDD be recognized"
It means you should move the Main Controller IC (the biggest chip on the board) from your original PCB by using hot-air gun, and then solder it on the replacement board. Move the Main Controller IC is a complex job which need you have certain technique. Some electronics repair shop can do it.
Here is the kind of thing that the professionals actually do:
Fix Identification Problem caused by Corruption of ATA Overlay module or ROM content:
http://web.archive.org/web/200910011647 ... m-content/
As you can see, it is essentially a simple, non-invasive job. You can purchase the software for much less than the cost of a typical data recovery. There is one PCB supplier who purports to provide a free PCB adaptation service, but I would feel remiss if I didn't alert you to the following threads:
viewtopic.php?f=1&t=25524
http://www.tomshardware.com/forum/29438 ... ment-again
PostPosted: June 10th, 2013, 18:28
Here are some bigger pics and yes this is how it came back to me :
PostPosted: June 10th, 2013, 18:40
Dammnnn.. I bet there's all kinds of delamination and maybe torn vias in there. At least the local electrical and high-frequency characteristics will have changed.
I can do better with a safety pin and a $10 iron from radioshack! And I kid you not! heat each pin, and lift a fraction of a mil. Repeat 99 times as you work around the chip.
Of course that is no substitute for a solder pot or temp controlled airgun with shields and airflow guides and all that.
Exactly which company did that, what's their website?
PostPosted: June 10th, 2013, 18:49
BGA chips are a little harder to move because you usually need two sources of heat (top and bottom) and decent amount of practice.
Sometimes (preferably always) the chip needs to be re-balled (new pads of solder applied) before you can solder it on another PCB and you'll need special stencil for that
And w/o practice it is very high chance to damage chip pads while taking it off the PCB. That will damage the chip permanently.
Bottom line is - the cost of proper tools(and no practice) will be more than the cost of moving the chip to another PCB at the place that specialize on that kind of repair.
Keep in mind that the chip might be already dead and all that could be for nothing.
PostPosted: June 10th, 2013, 18:57
I can't see the soldering work around the SMOOTH chip. The image is too blurry. I get the best results with a flatbed scanner.
I would compare any discernible part numbers against those of a good PCB. Maybe the wrong SMOOTH chip was used?
PostPosted: June 10th, 2013, 19:24
I tried what you said with my flatbed scanner but still the chip is unclear for me to post.
Also I got you pm, but can't reply yet because I'm too new to the forums. TY for your advice.
PostPosted: June 10th, 2013, 21:19
Contact scanners can't scan 3D objects.
PostPosted: June 10th, 2013, 21:46
Well, I know one place I won't ever be asking to do work on my boards for now! For the record, I do SMD reflow work here, though mostly I'm manufacturing assemblies rather than repairing them ( I repair a few since not every initial reflow works 100% and you have to manually redo it ).
What bothers me in this case is that it was "only" a TQFP chip, which are fairly easy to remove and replace - possibly it has a ground plane contact on the underside but even still the damage done to that board far exceeds what needed to be done. It's scary what "professional" services can get away with.
PostPosted: June 10th, 2013, 22:12
There is a chance that SMOOTH chip is not the problem or not the only problem
But anyway, ROM is inside Marvell chip, not SMOOTH chip
PostPosted: June 10th, 2013, 22:34
Agreed. Especially all the little problems that are easily dealt with hands-on. If DIY succeeds and doesn't become DIY then congrats and a tip of the hat.
PostPosted: June 10th, 2013, 23:17
IIUC, the OP had an unspecified problem with the original PCB. Unless I'm mistaken, "Datapro" determined that the SMOOTH chip was faulty and replaced it. Either something went wrong, or the diagnosis was incorrect, so now the OP has purchased a donor PCB and is contemplating transferring the MCU from patient to donor.
If the OP is prepared to make a few measurements, I could help determine whether this process has any chance of success.
PostPosted: June 10th, 2013, 23:21
My hires "photos" were produced by a Canon multifunction printer/scanner/copier, model MP370:
http://malthus.zapto.org/viewforum.php
I challenge anyone to get better results with their camera.
PostPosted: June 10th, 2013, 23:40
No need to challenge. Your scanner is not a cmos-contact scanner. It is a CCD based scanner. Completely different optical system. Not to mention a better quality detector array. Less cost cutting too.
http://www.carlmcmillan.com/dof/depthoffield.htm
http://en.wikipedia.org/wiki/Contact_image_sensor
PostPosted: June 10th, 2013, 23:55
Thanks for the heads up.
PostPosted: March 6th, 2016, 16:52
Are these the same people?
Photos
more
Sent Mail
My wd10tmvv-11bg7s0 not recognised
Inbox
S
sophia nagels
Hello My wd10tmvv-11bg7s0 not recognised as a usb device in windows and doesn't show up as of today in ubuntu I accessed my drive today and the fil...
Show 6 read messages
DataPro Data Recovery Lab
to me
2 hours agoDetails
Dear Shalom tsophia,
You can try board first,
We do have the same board as yours:
Total cost = $49.99USD (board+ firmware transfer+ shipping)
They are same PCB boards, but the board BIOS IC exchange is needed. Why ?
Because, for this model hard drive, each PCB BIOS IC is programmed by the unique original hard drive configuration data.
We have to copy this unique configuration data to the donor board and then the donor board will be compatible with the original hard drive.
We have two options for you:
Option 1. We do "BIOS exchange" for you for free, but you have to ship the original board to us.
We do BIOS exchange on failed board with 95 percent successful rate.
Option 2. You do "BIOS exchange" by yourself.
Please let us know your decision by replay this email.
when you ship the board to us,
for Western Digital hard drive ,please go to http://site.hdd-parts.com/WDF.php
Fill and Print the form and ship the Form and your board together to:
our mailing address:
DataPro Lab 528
15216 North Bluff Road
White Rock BC V4B0A7
Canada
The post office may ask you to fill the customs form
Please declare your damaged board value at $5 USD
or you will have to pay customs fees
Jason
This is my problem-
Photos
more
Sent Mail
Inbox
S
sophia nagels
to me
2 hours agoDetails
DataPro Lab 528
Canada
Jason
Sent: March-06-16 6:28 AM
To: DataPro Data Recovery Lab
Subject: Re: My wd10tmvv-11bg7s0 not recognised
This is the error report I did on this drive in ubuntu. I held the plug in hard to the drive while my son typed on the keyboard using GSMartControl in ubuntu 14.04. The drive only starts to read if the plug in the micro usb plug is held in at a difficult angle using both hands. Otherwise the drive spins a little and then stops. Do you think a donor board identical to this would assist, as it would have a new chip on there giving the motor the correct speed and if there is any problem with the micro usb socket then a donor board would have a new one on it? It doesn't have a repeating clicking like a head stuck on the platter. Here is the test results. And if you think you have a donor that would work with this all the details are in this report, then please let me know so I can purchase a donor from you.
shalom
smartctl 6.2 2013-07-26 r3841 [i686-linux-3.16.0-45-generic] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital My Passport (USB, AF)
Device Model: WDC WD10TMVV-11BG7S0
Serial Number: WD-WXQ1AC0F5932
LU WWN Device Id: 5 0014ee 1590f0a05
Firmware Version: 01.01A01
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5200 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Sun Mar 6 16:02:01 2016 IST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
Warning: This result is based on an Attribute check.
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (24600) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 282) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x7031) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 172 151 021 Pre-fail Always - 4366
4 Start_Stop_Count 0x0032 080 080 000 Old_age Always - 20140
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 097 097 000 Old_age Always - 2652
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 098 098 000 Old_age Always - 2337
192 Power-Off_Retract_Count 0x0032 198 198 000 Old_age Always - 1649
193 Load_Cycle_Count 0x0032 186 186 000 Old_age Always - 43007
194 Temperature_Celsius 0x0022 121 093 000 Old_age Always - 29
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 2652 -
# 2 Short offline Completed without error 00% 2652 -
# 3 Conveyance offline Completed without error 00% 2649 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
What is the most efficient move I should take?
PostPosted: March 6th, 2016, 23:15
The SMART data look good.
It sounds like you may have a problem with a flimsy USB connector. Have you examined the USB pins on the PCB?
Try a USB 2.0 cable. USB 2.0 and USB 3.0 use different signal pins.
Users browsing this forum: Google [Bot] and 61 guests
