 Post subject: NO SPIN - Hitachi CLA3
PostPosted: June 16th, 2013, 13:36
History: 2 HDDs same model. Dead after power surge at a time. 1 drive is fixed by swapping PCB only. 2nd drive has additional damage.
Hitachi HDD: HDS721050CLA382
Symptom: NO SPIN.
Findings: PCB Dead.
Action: Replacement with ROM.
Status: Still NO SPIN. But READY In HD Doctor. Load From HDD brings Error.
Next Suspect is FW. All modules corrupt/bad in SA-A & SA-B. SA-C has no access so far
Another task: It spins now for few seconds & SPIN DOWN again when it's connected without HDA contact. But Status is BUSY in this procedure, never READY.
So, what do you think? What would you do?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: NO SPIN - Hitachi CLA3
PostPosted: June 16th, 2013, 14:34
1) Killed headstack
2) Other problem not addressed in PCB.
Use DDA or similar to see what happens at HDA connector.
The behaviour of the PCB is similar in case of such failure (too few details).
8)
PostPosted: June 17th, 2013, 13:47
BlackST wrote:
1) Killed headstack
8)
Well, If it's the headstack - there are no CLICKING/TICKY etc...
What other problem are you referring that was not addressed?
By the way, I am not familiar with DDA (can you state please?)
What else do you need regarding PCB. (I ensure you the PATIENT PCB Is DEAD), & it's not the first scene like this case. I also noticed same problem in more 2 drives. 1 is 160GB and another one is 1TB (All the drives are CLA3 family)
__________
THANK YOU
SHAHI
PostPosted: June 17th, 2013, 14:18
Man, if you think you know it all, why ask here?
PostPosted: June 17th, 2013, 14:32
You seems didn't get my point. Ok, I rewrite: Patient PCB is dead as well as additional problem exist. But I can't catch the additional problem so far, that's why I am asking.
PCB is fixed by DONOR, but even after matching PCB, it doesn't spin, it only spins with DONOR when the PCB is connected without HDA contact. For few seconds only it spins and spin down. The same behavior I noticed into 3(three) CLA3 hdds so far. Did you face the problem earlier on these CLA3 HDDs?
Do you think it's NVRAM failure as well?
__________
THANK YOU
SHAHI
PostPosted: June 17th, 2013, 14:46
"it only spins with DONOR when the PCB is connected without HDA contact"
Thta's why can perfectly be the headstack.
PostPosted: June 17th, 2013, 14:55
__________
THANK YOU
SHAHI
PostPosted: June 21st, 2013, 9:51
preamp is dead
PostPosted: June 21st, 2013, 15:33
If you upload a detailed photo of the PCB, I could help you locate the supply and signal pins for the preamp. We could then compare your two drives.
PostPosted: June 22nd, 2013, 2:50
Shahij, instead of wasting your time with another analysis, in absence of DDA, why not replace heads with working pcb? 20 minutes and if everything is ok you should be done (if you don't have other problems around of couse).
PostPosted: June 22nd, 2013, 2:55
See the pic
http://www.hddzone.com/index.php?main_p ... ge&pID=356
http://www.drivestar.biz/hitachi-0a71256-p-2096.html
__________
THANK YOU
SHAHI
PostPosted: June 22nd, 2013, 2:56
NO Clean Room service here. Need to outsource abroad if headstack is the scene.
__________
THANK YOU
SHAHI
PostPosted: June 22nd, 2013, 2:59
Ouch ! :( that's a problem !
PostPosted: June 22nd, 2013, 4:29
Symptom: NO SPIN.
Findings: PCB Dead.
I think the original problem was PUIS enabled on the drive!
PostPosted: June 22nd, 2013, 5:19
Symptom: NO SPIN.
Findings: PCB Dead.
Today got the 4th Drive in hand with similar problem.
all the drives are from CLA3 series.
I did START MOTOR. Nothing happens, Very busy then error.
__________
THANK YOU
SHAHI
PostPosted: June 22nd, 2013, 7:25
shahij wrote:
Those are two different boards. I need a detailed photo. A quick analysis will take only 1 minute and will tell you whether you really do have a preamp problem.
http://www.drivestar.biz/images/pcb_ht/OA71256.jpg
http://www.hddzone.com/images/HTS10033.jpg
PostPosted: June 22nd, 2013, 14:56
sorry, i gave you 2 different. 1 wrong and another right pcb link.
here is the right no...
http://www.drivestar.biz/hitachi-0a71256-p-289.html
__________
THANK YOU
SHAHI
Users browsing this forum: No registered users and 249 guests
